For sale
Sa belt 4 point harness , black with shoulderpads
80$ono
Rb20 turbo no play. Can cometh dump/front/elbow .60$ono
R32 catback exhaust big hap system with cannon not too loud good street exhaust.150$ ono
Gutted 3" cat 30$
R32 back seats 80$
All boot trim and carpet make an offer
0435163144 plz text or call coz I don't check pm's
SHED CLEAN OUT
All items located in the eastern suburbs near Norwood
1. RB25DET coilpack/valley cover $30
2. RB25DET Standard front/dump pipe $30
3. S14/S15/R33/R34/Stagea Rear Camber arms with bushes $20
4. S14/S15/R33/R34/Stagea Rear Toe arms with bushes $20
5. Redline Shockproof Lightweight gearbox oil 2 x Quart bottles $20ea
6. OBD 2 Consult to serial cable w/ Belkin Serial to USB adaptor $80
7. Set of 4 tein coilover bump stops $10
8. RB25DET Side mount intercooler $20
PM ME
SHED CLEAN OUT
PM ME
redline oil is in the bin thanks to my old man.... :/
R33 GTST MANUAL ACCELERATOR/BRAKE/CLUTCH PEDAL SET SOLD PENDING PAYMENT
RB25det sump $30
R33 sr2 wing needs paint $30
R33 gtst sr1 front wiper motor $30
R33 gtst sr1 rear wiper motor $35
R33 gtst sr1 bonnet hinge set $15
R33 RB25 skyline power steering reservoir with lines $20
RB25det sr1 stock injectors all work fine but some have broken plasic ends but can replaced $20
RB25det sr1 aac valve $40
fiberglass vent (uncut vent) $50
R33 gtst sr1 abs unit and bracket $60
Rb25det sr1 flywheel $40
R33 gtst coupe sr1 door handle's $30
R31 sr3 grill $10
R31 sr3 bits lot $15
R33 rb25 engine mount brackets(mounts are rooted as seen in pic)$25
R33 gtst light garnish $30
R33 centre interior light plus other? $25
R33 turbo oil drain pipe $10
rb25det sr1 crankshaft(pulled from running engine with 80k and only 10psi stock turbo) $70
r33 horns $10
Nismo muffler 2.75mm inlet with 4.5inch tip $100 plus rear section that suits r33 free with muffler
RB hard oil turbo line $25 (not sure if its rb20 or rb25)
RB hard water turbo line 1 $25 rb20 rb25?
RB turbo hard water line 2 $25 rb20 rb25?
R33 gtst window wiper set $ 15
R33 gtst sr1 passenger side electric window switch and loom $45
R33 gtst sr1 2door seat belts(not sure if its complete) $50
R33 gtst sr1 air con units that sit behind the dash $90
RB20 RB25 Coil Pack Mounting Brackets(might be some bolts missing) $20
pioneer reverse camera bought it 2 years ago for $100 from jb hifi but never used it. $25
vr v6 commodore sedan fuel sender and pump(pulled from running) $40
r33 boot latch with plug $20
R33 boot and fuel lever $15
R31 1989 oz spec bonnet latch and lever $15
R33 a/c receiver,drier sensor $30
rb25det fuel modulator with bracket$25
R33 gtst R/H drivers door glass $40
R33 gtst L/H drivers door glass $40
R33 rear window $70
R33 gtst front fenders rolled and liped $170 for both
R33 stereo brackets $20
R33 sr1 dash trim(needs a clean and paint) $40
R31 sr3 4door window wiper and headlight indicator switch stalk(in good working condition) $25
r33 sr1 bonnet in primer$100 has a small dent(can send pics)
R31 oz spec sr3 89 dash painted in black with the correct die paint and half day preping the dash(hard to scratch but if you do, the die paint can be touched up with out a trace. The dash pad is still in stock brown but in good condition. what you see in the pics is what you get. Only selling as im going custom dash for track car. Items are a bit dusty as they have been sitting in my shed $50
R33 gtst false rear wall $20
R33 gtst sr1 coupe rear quarter trims LEFT & RIGHT they just need a clean but in good con $50
RB25det stock dump on black vht $20
R33 gtst rear bar with gtr pods both will need repair $50
r33 gtst sr1 power window motor regulator LHS $80
r33 gtst sr1 power window motor regulator RHS $80
R33 gtst rb25det hicas computer $60
ARP RB20 RB25 HEAD STUDS BOLTS KIT NEW NEVER USED $150(was going to build a forged rb25 for my 31 but now need money for another project)
ARP rb25 Exhaust Manifold Kit new never used $100
R33 bonnet in black primer has a small bend in lip $50( can get pic)
R31 1989 sr3 front calipers( pulled from running car but have been sitting for 3 years) $30
I have r33 interiour parts, pm for what you after
pm me or sms 0435 888 239
Will post at buyers expense
dave
r33 s2 complete doors - white
r33 gtr front grill brand new never used
nismo steering wheel with boss kit
veilside bodykit to suite r33 s1
4inch cat back exhaust with 5 inch cannon (exhaust is cut in half) has no muffler or resinator straight piping sounded insane
offers for anything pm me
can you please add a price that you hope to get for these parts
Thanks
sorry, dont even know really
grill - 160 or so
doors 125 each or 200 for both
cat back exhaust 100
steering wheel 75 or something
bodykit 150
dohmar ill send u a pic tonight when im home from work, if u wanna pm me your mobile number i can probably send you one during the day.
cheers
items FOR SALE:
  • Twin tip straight pipes made from high grade stainless steel $150 firm designed to be flanged under the sub frame/ diff originally came from exhaust technology. very good quality pipes. suits R32.May suit other Nissan models.
  • Standard r32 GTS-T series 2 steering wheel (rare with leather horn button not plastic black one) mint condition no rips or tears,stitching is perfect $150 firm best you will find pics on request.
  • Standard r32 RB20DET injectors x 6 $100 firm come complete with o rings and seals, came off my 20 for GTR injector upgrade last kms was about 115,000. Good condition no leaks.
  • Midnight blue R32 GTR front bar (not N1) genuine plastic with genuine un cut GTR reinforcement, factory mesh and number plate bracket and custom made tow strap fits between lip and bar $600 firm will not split. sold as a package.
  • Original side repeaters mint condition on fascia sides x 2 one has broken top clip supplied needs plastic welding $100 for both or $50 each. Not supplied with globes and holders.Suits replacement.
  • Genuine din pocket with spring loaded front cover flap fits in center of dash near climate control and cd player. suits r32 skyline $30 mint condition
cheers guys please call me or text me on 0421675373 if there are any questions or interest. Im not on here alot anymore :(
regards BEN.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
