moving house so keen on getting rid of all this stuff
not asking for big bucks just want em gone
mainly just want a few $ for the catch can as it cost me like 80 or 90 bucks i think
catch can - 50
can put a filter on top, or do whatever with it
other stuff
boss kit dont know if universal or whatever, fit my 33 with a nismo wheel
rb25 valley cover
4 floor mats, i think two are from a gtr and two are from a gtst
all the air con stuff from a 32 gtst
carbon canister and the lines
rb20 cam covers (no timing belt cover or valley)
rb20 clutch fan
r32 gtr weathershields id assume fit gtsts
r33 gtst door cards i think when i last looked in decent condition
R33 door used to be white needs to be sprayed but still got stuff inside it like glass etc... think it has the mirror in white too
most things can go for free just ask
pics if wanted PM me
heres a couple
For sale rx4 4 door/ 929 coupe package deal
$8500 ono
1974 rx4 4door flat nose model
The good.
Mark mills built 13bt mild port
s6 rotors 2mm scr seals
s5 turbo
microtech lt 10
Bosch coil pack
3"dump ,exhaust hooker muffler
PWR radiator
PWR intercooler
spl thermo
s4 gear box /rx4 bell housing H/D organic clutch
bosch 044 carter pre pump and surge tank
also comes with 700cc sard injectors not in car
16" wantabee rims
car made around 185rwkw on 6-8 psi engine has done less than 10000 since rebuilt and never boosted
the bad the body is rusty and but still registred and defect free
Thegood complete 929 coupe rolling shell just minus engine has rx4 flat nose front end conversion in primer very straight both cars as i bought them very sad to see them go but baby n.o. 3 on the way not much time for so many projects.
So some of them have to go i suppose.pls pm can txt pics
bump
For sale D1 Drift seats brand new, only 2 days old.
Was going to put them in my 34 GTT but can find seat rails to match
and not paying 500 big ones for custom ones, (thats each).
$500 for both, they are black and grey in colour,
They came will universal rails so come take them as well.
PM me if you are keen
Need them gone asap so i can get newish standard ones
Pics if you need them.
19x8.5" +35 speedy cheetah
5x114.3 suit ford/nissan/toyota.
Bought for my BA XR6T but have decided to put money to new FMIC & Tune rather than looks.
Good condition, some gutter rash but only 1-2cm marks Selling as bought, boxed and ready to go
$690ono
Need this stuff gone! make an offer on anything.
Stainless steel top mount manifold suit rb20/25
MTX jackhammer 12" 250wrms in ported box
kicker 400wrms mono block amp
standard rb25 turbo
50mm external wastegate (4 bolt flange)
intercooler piping suit rb25 with standard position turbo and crossover
2x 14" steelies with good tread suit honda
dell 24" full HD pc monitor, hdmi etc.
PM if you're interested :) cheers
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
Carbon canister?
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
How'd they look on the GTR when you had it?
Stainless steel top mount manifold suit rb20/25 with 2 bolt 38mm wastegate flange (BRAND NEW) $200
Stainless steel top mount manifold suit rb20/25 with 4 bolt 50mm wastegate flange (USED) $300
MTX jackhammer 12" 250wrms in ported box $100
kicker 400wrms mono block amp $100
standard rb25 turbo $125
standard S1 RB25DET coil-packs $30
50mm external wastegate (4 bolt flange) $40
intercooler piping suit rb25 with standard position turbo and crossover $50
2x 14" 4x100 steelies with good tread suit honda $30
Open to offers guys, need this stuff gone. All in good working order.
Pics on request.
PM if you're interested or txt me on 0425366582 :) cheers
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
Real Garrett GT3071R, good condition, next to no shaft play. Rear blades are mint, front blades have some very small chips in a couple of blades but doesn't affect the performance of it. Came with a car I bought but doesn't suit my needs. Already off and ready to go, can throw in a stangard manifold with a spacer welded to it to suit the turbo but will need something sorted out to run an ex gate.
Garrett GT3071R CHRA
(Product Code: 700177-5023)
Description:
Turbo Charger model
GT3071R
CHRA
700177-5023
Compressor Wheel Inducer Size (mm)
53.13
Compressor Wheel Trim
56
Turbine Wheel Exducer Size (mm)
54.98
Turbine wheel Trim
84
$850 ono
May swap for R32 suspension parts (except coiloves), oil cooler set up, or just something of interest.
Edited by Import S13
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
