moving house so keen on getting rid of all this stuff
not asking for big bucks just want em gone
mainly just want a few $ for the catch can as it cost me like 80 or 90 bucks i think
catch can - 50
can put a filter on top, or do whatever with it
other stuff
boss kit dont know if universal or whatever, fit my 33 with a nismo wheel
rb25 valley cover
4 floor mats, i think two are from a gtr and two are from a gtst
all the air con stuff from a 32 gtst
carbon canister and the lines
rb20 cam covers (no timing belt cover or valley)
rb20 clutch fan
r32 gtr weathershields id assume fit gtsts
r33 gtst door cards i think when i last looked in decent condition
R33 door used to be white needs to be sprayed but still got stuff inside it like glass etc... think it has the mirror in white too
most things can go for free just ask
pics if wanted PM me
heres a couple
For sale rx4 4 door/ 929 coupe package deal
$8500 ono
1974 rx4 4door flat nose model
The good.
Mark mills built 13bt mild port
s6 rotors 2mm scr seals
s5 turbo
microtech lt 10
Bosch coil pack
3"dump ,exhaust hooker muffler
PWR radiator
PWR intercooler
spl thermo
s4 gear box /rx4 bell housing H/D organic clutch
bosch 044 carter pre pump and surge tank
also comes with 700cc sard injectors not in car
16" wantabee rims
car made around 185rwkw on 6-8 psi engine has done less than 10000 since rebuilt and never boosted
the bad the body is rusty and but still registred and defect free
Thegood complete 929 coupe rolling shell just minus engine has rx4 flat nose front end conversion in primer very straight both cars as i bought them very sad to see them go but baby n.o. 3 on the way not much time for so many projects.
So some of them have to go i suppose.pls pm can txt pics
bump
For sale D1 Drift seats brand new, only 2 days old.
Was going to put them in my 34 GTT but can find seat rails to match
and not paying 500 big ones for custom ones, (thats each).
$500 for both, they are black and grey in colour,
They came will universal rails so come take them as well.
PM me if you are keen
Need them gone asap so i can get newish standard ones
Pics if you need them.
19x8.5" +35 speedy cheetah
5x114.3 suit ford/nissan/toyota.
Bought for my BA XR6T but have decided to put money to new FMIC & Tune rather than looks.
Good condition, some gutter rash but only 1-2cm marks Selling as bought, boxed and ready to go
$690ono
Need this stuff gone! make an offer on anything.
Stainless steel top mount manifold suit rb20/25
MTX jackhammer 12" 250wrms in ported box
kicker 400wrms mono block amp
standard rb25 turbo
50mm external wastegate (4 bolt flange)
intercooler piping suit rb25 with standard position turbo and crossover
2x 14" steelies with good tread suit honda
dell 24" full HD pc monitor, hdmi etc.
PM if you're interested :) cheers
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
Carbon canister?
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
How'd they look on the GTR when you had it?
Stainless steel top mount manifold suit rb20/25 with 2 bolt 38mm wastegate flange (BRAND NEW) $200
Stainless steel top mount manifold suit rb20/25 with 4 bolt 50mm wastegate flange (USED) $300
MTX jackhammer 12" 250wrms in ported box $100
kicker 400wrms mono block amp $100
standard rb25 turbo $125
standard S1 RB25DET coil-packs $30
50mm external wastegate (4 bolt flange) $40
intercooler piping suit rb25 with standard position turbo and crossover $50
2x 14" 4x100 steelies with good tread suit honda $30
Open to offers guys, need this stuff gone. All in good working order.
Pics on request.
PM if you're interested or txt me on 0425366582 :) cheers
catch can - 50
other stuff
rb25 valley cover
rb20 clutch fan
heres a couple
Real Garrett GT3071R, good condition, next to no shaft play. Rear blades are mint, front blades have some very small chips in a couple of blades but doesn't affect the performance of it. Came with a car I bought but doesn't suit my needs. Already off and ready to go, can throw in a stangard manifold with a spacer welded to it to suit the turbo but will need something sorted out to run an ex gate.
Garrett GT3071R CHRA
(Product Code: 700177-5023)
Description:
Turbo Charger model
GT3071R
CHRA
700177-5023
Compressor Wheel Inducer Size (mm)
53.13
Compressor Wheel Trim
56
Turbine Wheel Exducer Size (mm)
54.98
Turbine wheel Trim
84
$850 ono
May swap for R32 suspension parts (except coiloves), oil cooler set up, or just something of interest.
Edited by Import S13
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
