R33 Floor Mats(front only) - $30
R33 Series 2 Coil packs (1 found to be shorting) no attempts to fix it, car's high kw was asking a lot of them(was happy at 297kw, not so happy at 360kw) - All 6 for $200
Tial GT30 0.63 Turbine housing unused in the box and 100% Genuine!! - $450
Brand new walbro intank pump Gss-342K - $120
Iphone 4 black 16gig with box and chargers no scratches - $300
Entertainment unit - $50
Pick up northern suburbs of SA
PM please as I don't always check this section
Sard 700cc injectors to suit rb26/20, roughly 5000km old. replaced due to e85. $500
2x R34 N1 turbos (2860-7's), one is fine but the other needs to be rebuilt with new bearings $600
Turbosmart boost T $50
Delphi 1000cc injectors to suit rb26/rb20, they are low independence and straight bolt in. Brand new in the packets $400
0433943034
$180 now!! Grab a bargain! Brand new CF 400r wheel arch flare set!
Edited by exclusive2u
Kicker sub and amp in a proper kicker ported box, plus full wiring kit. Pretty sure JBs still sell this same model for around ~$300 for sub alone.
Good kit, minimal use, only selling because I don't need it anymore. $250.
Bride drivers side, fixed rail (has two adjustments though) Came off a Stradia in a R32, believe the rail will also fit s13/180 etc. $100
Straight pipes, twin 3". $80
Some random brand podfilter with heat shield, think it's a 4", brand new unused. $20
Swing me a PM/text 0431308647.
Located in Mount Barker SA.
Cheers,
Chris
R33 gtst sr1 manual complete rear cradle diff to brake with slotted rotors and hicas lock bar $300
R33 gtst sr1 front 5stud hub, knuckle, lower and top arm, abs wires and brake hose $100 each side
R33 gtst sr1 power steering rack and cross member $100
R33 gtst sr1 manual rb25det complete wire loom with z32 plug and turbo timer $100
R33 gtst sr1 heater cores that sit behind the dash all three units $50
Pm me
Dave
R33 gtst manual pedal set $50
All parts for sale off or suited to r32 skyline:
Kakimoto cat back near new 750 worth 1250 new( n1 mega)
Carbon door skins, some scratches and tweeter holes cut, with electric window switches 200.
Headlights, pair 200
Toyo r888 295 18 only done a few laps bargain 1000
Front widebody guards 250
Bootlid holes welded and flushed no locks 180
Front pillar trims and rear skins very good condition 100
r32 gtr wing 100
I love these wheels, but I need 18's in my life.
17x9 +18 with 235/45 Achilles 123S (brand new), and 17x10 +20 with 255/40 Federal SS595 (~50%).
They were recently stripped back to bare metal and professionally painted in metallic silver, come complete with centre caps.
As usual with painted wheels, some paint has been stripped off the bolt holes by the wheel nuts, but it's only evident when you remove the wheel. There is some light guttering on one of the wheels, but again, it isn't really noticeable. I'll get pics of both up in time.
Very lightweight wheels, comparable to TE's. Plenty of caliper clearance, and they look tough on just about anything.
If you want more pics, just ask.
As for price... Taking offers above $2.5k.
Contact VIA pm. More than happy to organise test fitting for locals.
Cheers!
HKS GTSS .64 housing
suits CA18 and SR20
good condition
was run on my CA18DET and made 180kw on 14psi, could easily make 200k with more boost and is very responsive
$900ono
call or sms 0411160974
$800ono
got my 4/5 stud Rays Evo 3's for sale
17x8 +6 front with Federal 595SS
17x9 +19 rear with stuffed tyre's
both have a bit of rash but nothing major, front sits flush with stock S13/r32 guards, rear would need a bit of guard work
looking for $1000ono
$800
Items:
Set of Black R34 GTT Rear lights
R34 GTT Indicator and wiper/washer stalks
R34 GTT automatic dash with 80k
Item Condition:
Set of Black R34 GTT Rear lights - Has some scratches on the black surround
R34 GTT Indicator and wiper/washer stalks - Fairly good condition can send pictures if needed
R34 GTT automatic dash with 80k Mint condition
Contact Details:
Send me a private message if you are interested or would like to offer
Price and price conditions:
If you would like pics of the item i could take some and message them
These parts have been laying around for approx 2 years now and need them gone so message me an offer on a part and i will most likely take it up
Pick up for all parts with cash payment
Located at 5010 post code.
Need this stuff gone.
Items:
Guard roller - Great condition. $100
Splitfire coil packs (x6) - Part number SF-DIS-001. For RB20. Almost brand new. Only 2000kms old if that. Fantastic condition. $500
Splitfire loom plugs (x6) - Adapter plugs for the older RB coil pack loom (Cefiro, R31 Skyline, Laurel). Fantastic condition. $150
CA18DET oxygen sensor. Genuine Nissan. Brand new. $100
Car stands - height adjustable. 3000kg working load. Max height 420mm. Great condition, barely used. $50 for both.
Prices are negotiable.
PM me, or message me on 0434 030 114.
Edited by rayj
Non urgent sale. 0433 290 801
****WILL SWAP FOR EVO 8****
1997 FACTORY manual jzx100 mk2
104xxxkms (100,000 major service done)
Engine:
1jz factory manual
GCG hiflow turbo (3071)
Spare factory turbo (working fine)
Power Fc D-JETRO
brand new genuine bosch 940cc injectors
HPI dump/decat
tomei poncams
NEW shims fitted to the head when cams were done to make perfect clearances
Brian crowler valve springs
Brian crowler valve stem seals
blitz FMIC
factory airbox with new HKS panel filter
cusco front strut brace
Brand new battery
Blitz EBC
BRAND NEW genuine VVTI cam gear and VVTI solenoid fitted
Interior:
nardi deep corn
jvc DVD headunit
seiwa gearknob (long metal style)
Factory Rubbish bin
Air purifier
Exterior:
Factory HID's
S2 rear lights and boot
(spare S1 lights and boot)
cusco coilovers
cusco front and rear sway bars
solid rear subframe bushes
solid diff mounts
TRD 2way lsd
TRD full stainless exhaust
GENUINE RARE factory roof wing
GENUINE sunroof visor
origin boot lip
factory lip kit
Wheels:
comes with full set of stockies with mint tread
pending price.
VSKF burning black (low disc for best dish)
18x9.5 +19 with new achillies 225/40/18 (not ATR sport)
18x9.5 +26 with new achillies 225/40/18 (not ATR sport)
tuned to 240rwkw @15psi
*********NOTE does not come with CST's**********
*********can mms more pics if wanted *********
PICTURES - http://classifieds.nissansilvia.com/index.php?view=advert&t=2124847
HKS GT2535 Full Kit for R33 RB25DET. Great condition with minimal shaft play and ready to bolt straight up to your GTS-T.
Includes turbo itself, elbow and silicone joiner/shield, all lines, basically everything you need to swap out with your standard turbo. I'll include some new turbo to manifold bolts. An easy 250-260rwkw with supporting mods.
$900 ono. Pickup from 5098.
R34 Manual Conversion bits-
R33 5 Speed Manual box
R34 Pedals- Clutch, Brake & Accelerator
R33 Complete Manual Tailshaft
R34 Manual gearbox cross member
R33 Flywheel
$1800 ono the lot, 0466614799
$1400 without the pedals or tailshaft?
Hey guys
Im selling up all my parts and car. Getting out of JAP cars and back into the good old Valiants, so everything is up for sale!
My 180SX will be up for sale in the next couple weeks, details will follow. Those interested can PM me.
Some parts are new, some are s/hand but done very few km's. More parts will be added as I sort through them all, so stay tuned.
Ill kick it off with these, more to follow next week!
HKS cam gears $300
Tomie RAS $60
Greddy Profec B spec 2 $250
S13 SR HKS step 2 264/264 dur 12mm/11.5mm lift $400
HKS Twin Spark with plug and play s13/14 loom, also comes with multi fit 4cyl/6cyl loom $400
MOMO deep corn 350mm siam, 80 dish $250
HKB boss kit for S13 non hicas $30
Oil catch tank with hoses $80
RH front 180sx guard $130
R32 front lower control arms $120 pair
NISMO light weight flywheel $250
Grex/TRUST gear knob $60
WORK wheel nuts. 1.5 sets of nuts/lock nuts. some still new. $120
Nissan rebuild kit for BM50 ABS brake master $40
INITIAL D sun visors (RARE) $100
S13 redtop O2 sensor $30
More parts to follow
Cheers
r33 exhaust system, front split pipe $150 apexi cat back looks like 4" deleted centre muffler with apexi muffler $250
r33 s1 headlights $280 no broken bkts etc
r33 cusco adj coilovers $650
r33 front calipers and rotors $280
17" mesh rims 80% front tyres wear marker rears $600
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
