ive got some stuff i need to get rid of.
5 stud nissan rear hubs, bearings in good condition $100
RB25 ecu $100
S14 engine loom in perfect condition with ecu $150
S14 LCA complete with adjustable castor rods $150
4.08 Locked S13 diff complete with halfshafts $200
located Adelaide SA, can ship most parts at buyers expense
Tein Hr front r32 gtr Coilovers Good condition no leakes unsure spring rate $600 ono
R32 gtr abs unit $300 ono
r32 gtr brake master cyl n booster $200
gtr front hubs and upright $200
Front shafts
ps rack and resivour $150
Bare front cut gd for repairing ure smashed front
32 air vents
Rb25 stall converter &torque plate
Rb25 power steer pump
Rb25 ac compressor
Auto rb starter motor
Rb20det running condition need harmonic balancer and oil pump put on complete minus coils 800
rb20det extreme heavey duty clutch $250
Rb25 internal gate
Rb25 neo throtle body
Rb20 throttle body
Rb25 intake manifold
S13/180/32 stock rear camber arms
32/s13 rb front crossmember withvrack
R32 front strut brace
180/13 cusco strut brace front
180sx doors with glass wnd power motors
180 tailiights n garnish
Drift pineaplles
R200 diff housing various gears
32gtr front guards
33 steering colum and lock key
33 hks super draggerr exhaust
- Walbro 255 fuel pump - Brand new never used (has been assembled) - $160
- 3" SS highflow cat (no flanges) - Brand new - $160
- BMC pod filter - Used, still decent condition - $25
- 600W Kenwood (old style) amp, 4/3/2 channel - Used, few marks, still works perfectly fine - $120
- Nissan short bosskit, fits Cefiro/S13/S14/R32/R33's without Hicas/Airbag - Brand new - $60
- R33 S2 RB25DET stock ECU - $120
- R33 S2 RB25DET wastegate actuator - $40
HKS GT2535 Full Kit for R33 RB25DET. Great condition with minimal shaft play and ready to bolt straight up to your GTS-T.
Includes turbo itself, elbow and silicone joiner/shield, all lines, basically everything you need to swap out with your standard turbo. I'll include some new turbo to manifold bolts. An easy 250-260rwkw with supporting mods.
$900 ono. Pickup from 5098.
Can't believe this hasn't sold. Price reduced to $800. Come on people, $800 for a HKS bolt on turbo kit in great nick!
Makes me sad I pulled it off the car at this price.
Hey guys,
its time to let my Legnum go, my house is about to be built and im looking for something a bit smaller and more economical.
Make: Mitsubishi
Model: Legnum
Body Type: Wagon
Year: 1998
Mileage (Km): 116,500
Transmission: Automatic - tiptronic
Drive Train: All Wheel Drive
Fuel Type: Petrol - Premium Unleaded
Colour: White
Air Conditioning: Yes, works great!
Mitsubishi Legnum VR4
Auto / Tiptronic gearbox
Twin turbo
Factory Nardi wheel
double din touch screen cd/dvd/etc etc player, can even hook up TV tuner if you wish!
Tyres in great condition all round
Other than the rims, the car is completely stock.
Price is $12,000 ono, will part-trade for a non-turbo manual S13 or 180sx only.
More pics available on request.
Please message or call only, i dont check my messages on here. 0416 070 133
basically complete rb25 head mint cond. no oil cap or valley cover. $150
r33 gtst s1 guards both for $50 good condition. red.
all just wasting space basically..
tein rear coilovers for s13/180sx/r31 good condition
also suites r32 rear. aswell as front if you want mad low.
$375 ono
PM me and ill text pics through
thanks
These rims are still for sale.
Also to add to it,
I work away so best to PM me as I'm nearly always out of reception but can get internet most of the time.
For Sale or swap for R32 parts
Garrett GT3071R, next to NO shaft play at all, rear blabes perfect, front blades have very small chipping in a couple of the blades. This turbo came with my car but I never had the car running while it was on there so mechanical condition is unknown to me other than what I can see so that's why it's cheap.
Turbo Charger model
GT3071R
CHRA
700177-5023
Compressor Wheel Inducer Size (mm)
53.13
Compressor Wheel Trim
56
Turbine Wheel Exducer Size (mm)
54.98
Turbine wheel Trim
84
Can throw in a standard RB manifold with a spacer welded on it to suit the turbo. Will need to sort out how you want to run the Ex Gate though if using the standard manifold.
$350 or swap for some R32 parts
Rims sold, turbos still for sale.
$350 for the turbo
RB25 Turbo, came off an r33, was running wastegate pressure when I bought the car (7psi?), good condition overall - $350
RB20/25 bellmouth dump pipe, good condition - $120
R32/33/s14/s15 boss kit (no hicas or airbag) with brand new dished suede steering wheel - $120
R33 AM Performance split pipe catback system, 5,000km old - $500
PM or 0422 314 938
Got a bran new apexi data logit that im looking to sell as im thinking of selling my power fc too.
Its so new i havent even plugged it in and used it yet. Comes complete with everything needed to use the program.
$300 I can post if need be at your expence.
RB25DET r33 turbo with oil and water lines. Good condition the usall slight shaft play. Doesn't blow smoke. Due to upgrade i no longer need. $300
RB25DET exhaust manifold. Due to a GTSR manifold i no longer need. $100
RB25DET standard injectors with out rail. Upgraded to larger items. $100
RB25DET inlet manifold. Doesn't come with throttle body or tps. Going ffp so i no longer need. $80
All items are for a S2 motor. If serious please pm me.
Adam
Got R33 S1 interior bits for sale
Back seat
Boot Carpets (not pictured)
Automatic Centre Console
Ashtray
Automatic Instrument Cluster with 149k on it
Space saver
Make an offer.
Stock steering wheel is already sold.
I will have more interior bits up soon,
probably carpets (not great condition)
Roof lining
Rear garnish trims etc.
Edited by Ricky_Bobby
Front shafts
32 air vents
Rb25 ac compressor
Rb25 internal gate
Rb20 throttle body
Drift pineaplles
32gtr front guards
price on stock 25 intake manifold? has all bolt on bits etc?
Apexi AVC-R, great nic, everything you need $400ono
32 Cusco front camber arms, suit gts-t or GTR. again great nic 479AA $200ono
Silver R32 GTR front bar, cut for intercooler neatly, no lip $400
silver 32 GTR grill, most of the clips there $100
HDI electronic boost controllr, fairly basic, works fine $150
D1 spec steering wheel $50 (http://www.rhdjapan.com/hkb-d1-spec-deep-steering-wheel-340mm-50142)
Nismo gearknob 2nd hand, great nic $60 (http://www.visionr.com.au/images/site/products/409--32865-RN005.jpg)
thats about it at the moment
Josh
0411742212
parts in NE suburbs of SA, can post most of it
Josh
0411742212
Send pics of front bar plz........0433 522 234
R32 gtst turbo with 32 10psi actuator $100 minimal shaft play
Stock side mount intercoolers in good condition
R33 standard $20
R34 standard $50
Come with stock brackets shroud etc
Ca18de power steering pump $50
3 ok condition headlights for s13 silvia sr20 type $100
Hit me up. I need this stuff gone
Al 0423789155 southern suburbs
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
