  • 1 month later...
  • 4 weeks later...
For sale: R33 S2 Headlight with minor crack to back lens and supports.
Would be perfect for a plastic weld restoration as this headlight was purchased new for $550 two years ago. It has no yellow impairment and could also be used for parts.
$50
Hi guys
i have up for sale
2 x Air Flow Meters for RB26 out of and r33 $150 for the pair
a pair of the LED Tail lights untinted suit a lighter colour than midnight purple $120.00 ono
and a pair of the Carbon fibre B Pillar covers (non nismo) for $50.00 ono
let me know if your interested and i may be able to meet down Adelaide or ship out as i'm about 2 hours from town but head down every now and then
RB20 long motor
185-190psi compression on 1, 2, 3, 5, 6
90psi on 4. leak down shows it is a cracked piston ring
allegedly has GTR cams
head is still good. motor suit parts, thrash car or rebuild
$250ono
0416580223
  • 4 weeks later...
So selling 180sx due to defect and cant be stuffed getting it off
Blacktop sr20det
Engine dampner
Spaghetti manifold
Nistune
550cc injectors
Hybrid front mount intercooler kit
3 inch turbo back exhaust with blast pipes
Z32 afm
Twin plate clutch
Boost controller
Deep dish wheel
Gauges
Coilovers all round
Most suspension arms underneath all adjustable.
Making 236rwkw at 14psi
$3500
Contact Josh
0407792160
Edited by chefporkchop
Sold
Blacktop sr20det
Engine dampner
Spaghetti manifold
Nistune
550cc injectors
Z32 afm
Twin plate clutch
Boost controller
Deep dish wheel
Gauges
Coilovers all round
$3500
Contact Josh
0407792160
  • 1 month later...
Items:
Car magazines $100
z32 AFM $100
R33 radiator gtst $100
Blitz pod filter $40
r33 s2 gtst coil packs (6)
Item Condition:
70-80 mags. 75% HPI magazines from past 5 years. All items excellent condition. 45 day warranty
Extra Info:
Christies Beach
Contact Details:
Please sms 0412 048 601
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
