Hey Guys, Want this stuff gone! please Pm me with offers
S13/180sx
Digital Climate control + loom + Sensors - EVERYTHING $90
R32
R32 Tail Lights VERY Good Condition pretty shmick! $90 FOR THE PAIR!!!!!
one has a slight scratch, VERY light, probs lick your thumb and it will rub off.
rang up a few wreckers and they want $100+ for one! on ebay they are $90 each so grab your self a pair! comes with globes
I'll post photos on request, most of you know what the shit looks like!
PM me! I'm on everyday. Ill send if you pay postage, the Acc unit will be around 10 bucks, tailights your looking at more.
PICKUP, South Of Adelaide.
R33 Skyline Cusco Coil overs excellent condition: $800
R33 Skyline series 2 GTST/GTR Steering wheel excellent condition like new: $300
Cooling mist water/methanol injection setup: $500
Water methanol injection Setup only 4 months old send me your cross over pipe and ill send you mine with jet drilled and taped ready to go, also send me your washer bottle and ill send you mine modified to suit the water meth for the stock look. Also comes with relays and wiring ready to plug in all done.
Pair of 30mm Hub centric wheel spacers with nuts (used for 1 week only): $120
Edited by FOOLBOOST
4sp Auto gearbox $500
a/c control $120
ABS brake master cylinder $100
ABS unit $100
Auto Diff $280
Auto gear stick surround $40
Auto tail shaft $150
b pillar covers (pair) $50
back bumper $150
boot seal $30
carpet $100
center light $50
Centre console $70
cluster surround $50
driver door with glass and motor $200
driver mirror $100
driver side door frame and seal $50
Driver Side Headlight $250
Driver Side Mirror With Glass $60
front map light $50
Hood Lining $50
indicator stalk $50
Instrument cluster (auto) $150
passanger door frame and seal $50
passanger side kick panel $50
Radiator support $200
rb25 throttle cable $30
rear corner windows (pair) $150
rear door trims (pair) $100
rear handles (pair) $50
Rear seats $100
rear sway bar $50
rear view mirror $50
rear window $250
S2 Dash surround with clock, hazard switch and demister switch $90
S2 dash with air bag and panel $400
s2 roof liner $100
scuff plates $50
seatbelts (full set) $100
Standard Rb25 BOV $50
Stock airbox $50
tail lights (pair) $300
washer stalk $50
White boot with holes for GTR wing $100
white fuel cap $50
white rear garnish $70
all off a series 2 R33 Imported this year in mint condition
PM ME
img0756rs.th.jpgimg0758copy.th.jpgimg0759copy.th.jpgimg0762copy.th.jpgimg0763copy.th.jpgimg0764copy.th.jpgimg0765copy.th.jpgimg0766copy.th.jpgimg0767copy.th.jpgimg0769copy.th.jpgimg0770copy.th.jpgimg0771rscopy.th.jpgimg0772copy.th.jpgimg0773copy.th.jpgimg0775copy.th.jpgimg0778copy.th.jpgimg0779copy.th.jpg
YEAR- 1989
MAKE- Nissan
MODEL- S13 silvia - resprayed custom green – manual
PRICE- $9,000 ono
MODS
Ca18det
engine has received a full o/haul and metal head gasket
kkr 330 turbo fully rebuilt with garret gt28rs internals
supra front mount with custom piping and custom intake pipe
speed lab remap
gtr fuel pump
poly urethane engine, gearbox, and sub frame mounts
gtr rear sway bar, think front too
cusco camber and toe arms
moon face traction rods
poly urethane castor rod bushes
ram rod coilovers, gab front coilovers
lock spacers
brand new exedy clutch (seen 3 track days)
new clutch master and slave cylinder and lines
full turbo back exhaust
drift handbrake button
cusco mech 2 way lsd (also seen minimal track time since new)
skyline rear 5 bolt drive shafts
obx bucket seat
clarion head unit 45x4 and clarion 6x9 speakers
16x7-0 and 16x8 +2 ssr xr4 longchamps
Pink steering wheel (straight from japland :()
Front lower lip
Front and rear strut braces
52mm alloy radiator with all new JJ silicone piping
Big custom oil catch can
PICTURES SHOWN DO NOT HAVE THE GTR GRILL OR LOWER LIP FITTED YET BUT COME WITH THE CAR ON SALE
ALSO, THE CAR DOES NOT HAVE REGO BUT WILL HAVE 3 MONTHS NEW REGO ONCE THE CAR HAS A BUYER
CAR HAS A BLACK BOOT IN PICTURES BECAUSE OUR OTHER BOOT WAS GETTING THE SPOILER HOLES FILL. IT HAS A PAINTED AND MAXING BOOT NOW.
EXTRA COMMENTS car is fairly straight with the body work could use a little tlc, chassis is immaculate with no rust or dents in the floor pan, it made 176rwkw with the retune and has more in it if the injectors and AFM where upgraded, basically a tough street car with plenty in it for drifting.
This car has seen track time but not much at all. 3 times since January is it and it doesn’t get driven unless its going to the track. I do start it and roll around the winery where its kept in a shed at least ones a week to keep it healthy.
MORE PICTURES FOUND AT THE LINK
http://www.nissansilvia.com/forums/index.p...howtopic=420061
Have the following for sale, still on the car can see running etc, made over 300kw on 18psi with current tune, most parts are brand new and have just been fitted within the last 2 months, can buy the whole lot or will separate.
located in Adelaide
- Garrett GT35 Turbo with 0.5 front cover (faster spool then 0.7) and 0.82 rear IW & Custom Braided lines oil restrictor and custom turbo drain etc $1850
- Tune Length stainless exhaust manifold $300
- 3.5 "Bell mouth dump front pipe $350 suit gt35 IW
- 3" Silicon Hard intake pipe & Pod Filter $100
- Trust Side mount intercooler (uses short piping and goes back into stock piping) $400
- Z32 AFM with plug $250
- SARD 850cc side feed injectors with clips and loom all soldered in $850
- Yellow Jackets coil packs $300 suit r33 series 2
- Apexi Power fc + Apexi Commander with 300kw tune $1450 suit r33
- BLITZ Sbc ID3 SPEC-S Electronic Boost Controller $400
- Nismo 400r Sideskirts suit r33 $300
- Cusco Coil Overs $800
- 18" x 9.5 Dtm rush wheels stretched 235's new tyres front, 255's 1/2 tread rear $1500
- Rda slotted rotors & QFM-k750 hight temp pads $450
- Nismo Fpr $120
located in Adelaide
- Nismo Fpr $120
STILL GOT THE WHEELS?
Items:
bn style (i think) rear bar for sale
Item condition:
slight damage (see pics) but nothing a bit of fibreglass kit couldn't fix.
Contact details:
sms me on 0401043311, will try and get back promptly
prefer buyer to pick up but could arrange to have dropped off aswell
Price:
$200 ONO
still for sale!
Car:
PowerFC (R32/33 GTR) + hand controller $850
2x Motul 4l 300V Chrono Oil $75 each - SOLD PP
stock 32 GTR turbos $200
stock GTR injectors (new revision) $200
stock 32 GTR cam gears $40
stock 32 GTR harmonic balancer $20
stock 32 GTR dumps $20
Trust oil cooler (150mmx300mm) - use on engine oil at own risk, was in a car that spun a bearing $40
Computer:
4x tressels, white (1.8m x .7m) $75 each
1x satelite dish $50
Random:
Poker chips, 500 peice $40
DVD Box set series 1 of WPT $30
Scrubs Box Sets:
Season 1: $25
Season 2: $25
Season 3: $25
Futurama DVD Box Sets:
Season 1: $25
Season 2: $25 Unopened
Season 3: $25 Unopened
all i can think of atm.. PM me, all prices are pickup, happy to post at buyers expense
for sale is my 1994 r33 gts-4, car has done 180,000km im asking $6000 as is. the right hand side window motor is shagged, overall the car is good and in the past year and half of owning it i have never had any probs. i am located 6 hours of adelaide in roxby downs, i was going to get it turboed and make a track car but do not need it anymore due to buying a xr6 turbo.
Sold
As new (1 month old) xbox-360 elite 120 gig HDD, in original box, with standard accessories - with 1 controller, all leads (inc HDMI) and reciept from local DSE. It should also still have 1 month membership as I did not complete online registration.
Sold
Sold
R32 BN bodykit, genuine from Japan.
Condition: Used
Front bar: Need some love, and paint
Side: Good condition, needs a paint
Rear: Good condition, needs a paint
$650
Up for sale is the whole car wreck only (written off) its a 1994 ser 1 model with 164xxxkm still runs and can be driven too but obviously not on the road. has few after market extras
I am selling the car as a whole wreck only will not separate anything as i dont have the time and space for it i need it gone asap cos its been sitting around for a month now. Damage only on the right side of the car
What you see is what you get. inspections welcome.
comes with work maister SSR wheels 17x8 17x9 with 2 brand new tires & other 2 80%
2 wheels damaged as seen in pictures on the right side
3 inch turbo back exhaust
near new air flow meter cost me $400
tein coilovers suspension
Exedy heavy duty brass button clutch
Trust intercooler
Trust panel filter
Trust timing belt
Slotted rotors all around with endless SS pads
no stereo and speakers
redline diff and gearbox oil used
always serviced every 5000km with motul turbolight oil
any other question please feel free to SMS me the best
I am after $3,500 quick sale
Borko
0415 466 726
post-46081-1256439167_thumb.jpg post-46081-1256439259_thumb.jpg post-46081-1256439317_thumb.jpg post-46081-1256439392_thumb.jpg post-46081-1256439454_thumb.jpg post-46081-1256439518_thumb.jpg post-46081-1256439603_thumb.jpg post-46081-1256439667_thumb.jpg post-46081-1256439828_thumb.jpg post-46081-1256439965_thumb.jpg
NEED THIS GONE ANYONE????????????????????????????
Hey guys,
putting my R33 up for sale,
reason for sale is that im hoping to upgrade to a gtr!
Ive been the only owner since i imported from Japan (Japan Dynamics) through Iron Chef in late 2007.
1996/03 Series 2
KH3 Black
80,XXX Km's
5 Speed Manual
Factory bodykit - Skirts/Pods/Front lip
Electric Sunroof
Cold AC
BCNR33 Bootlid/Spoiler/Badges
SSR WRV Koenig Wheels 18x8.5fronts 18x9.5rears
Nankang NS2 Tyres 80% tread
Tein HA coilovers
Bolt-On Spacers
Rear Guards Rolled
Cusco front strut brace / Nissan factory rear strut brace
30% Tint on rear window / quarters
Kakimoto stainless steel exhaust
Decat pipe
Bellmouth Dump/front pipe
Blitz SUS metal air filter
Silicone Induction pipe
Boost Gauge
Speedlabs Remap
Bosch Fuel Pump
Turbotech boost controller
Front mount intercooler
Bride Seat
Quality Alarm w/ auto window roll up
Blitz voice guide turbo timer
Razo Ball type gear knob
Genuine Nissan floormats
Kenwood double din Mp3/Cd player
Dual cupholder :banana:
Always serviced with synthetic oils
Just had 100k Service done!
Will also come with a spare RB25 turbo in good cond. & stock suspension w/ HKS springs!
$12,900 ono
Any enquiries, PM me, call/sms 0433 280 274 or send an email to: [email protected]
Edited by AFTDRK
18 by 9 work rims 5 stud look great vip ish style similar to the koinegs above :P 800
17 by 8 and 9 rays chrome wheels with tyres 500 5 stud too :down:
pm me or msg 04333 07 918 and i can send u a pic
Edited by R324DOOOR
Exhaust for BNR32 or HCR32 (Will fit but might need to mod hangers apparently!)
Bought this exhaust from RBWARE about a month ago but decided to go with a single cannon on the GTR. Paid $400 for it so I'll take $350. Twin 2.5 stainless pipes that end in 3" twin tips (I think they're 3"). Old owner made 340kw and owner before him was making near 400kw so they flow extremely well.
PICS
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
