After researching I tried to fix this flat spot at about 3-4500rpm or so. I have tried setting the plugs at .8mm and it improved slightly. I have just bought yellow jacket coils and installed them thinking the old ones must have had it. If anything, it is now running worse! Good torque at up to 3000rpm and then it just goes flat and pulls a bit more at the end.
What on earth could it be?
Mods are:
Mail/road tuned Z32 ecu
Walbro GSS342 fuel pump
3" turbo back exhaust
GFB Boost T
K&N panel filter
Yellow Jacket coils
Running 11psi
cheers,
Dan
Edited by senilykSkylines
https://www.sau.com.au/forums/topic/354399-help-another-massive-flat-spot/
I would get a real tune done as apose to one of those mail order bride ecus! You may be able to make the car run better but not every motor is the same to run the same settings!
I did have a mail order but then the tuner did a road test to check that is wasn't pinging and that all was running fine. I've only notice the missing a little while after the tune was done.
So - The tuner reckons it was running fine during the road test (that is, no pinging OR flat spots OR missing) and you agree there was no flat spot or missing.
Since then its developed a flat spot and a miss - did those things happen at the same time? What has changed since the tune? How many kms has it been?
It's done maybe 5-10,000 km after the tune. It seemed to run fine around the time of the tune an it has been gradually getting worse.
I thought a miss was a flat spot? As in a stall in power, failure to ignite... possibly?
The spark plug gap and the coils have changed since the tune but I did those because I noticed it after the tune (not immediately) I hope it is not the tune but I was thinking possibly the airflow meter maybe? or wouldn't it be?
Nah - miss is where the fuel doesnt ignite at all, so it is rough running, running on 5 cylinders. Flat spot is just low power, but smooth.
I had a similair issue with a z32 ecu on mine..ended up going with a r32 ecu and seperate vct controller, the drama was the z32 ecu for some reason just stopped controlling the vct properly.!
Edited by honan
  • Gender:Male
  • Car(s):R33 GTS25t 1997
  • Real Name:Daniel
97 would be series 2, which means no igniter pack.
Ya, one of the last R33's made, when I had the new computer tuned we even had to change around a few pins that would not usually need to be changed.
What I don't understand is why would having new yellow jacket coils make it worse? They are new and suppose to be better.
I really hope i am not leaning out or my engine would be frying itself. I would have thought running it rich rather than lean would be what makes it go slower? Fuel pump is only several months old, unless there is a leak in the line after i installed, but then it wouldn't be pulling hard in the top end I would have thought.
I've emailed the tuner...
  • 1 month later...
Dynoed it and turned out to be (in theory) the intercooler getting too hot which triggers the knock sensor almost always at 4000rpm. FMIC is on the next to do list.
How does heat trigger the knock sensor? It's on the other side of the block, it's not affected by heat and has nothing to do with the cooler. Unless the heat is causing the engine to ping which would be strange because you said your tuner said it want pinging.
put the stock ecu in before to cause any damage. I had a pfc which had a tune for stock car and little more boost, sure the highest ping was 38 but it ran like arse. Put my stock in there yesterday and yanked out the z32 afm and it runs alot better, alot more power. If the tune is not on your car it's not for your car.
<i> Unless the heat is causing the engine to ping</i>
This is correct. Tuner sensed a "little pinging" on the dyno but the knock sensor was pulling it back sometimes when it sensed knocking. So it is not knocking badly at the moment, only a little when it is hot which the ecu picks up and takes care of. Goin to get a FMIC and try 98 octane instead of 95. cheers.
Your running RON 95 fuel on a GTS-T, and it has being modified for extra power? :(
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
