Bobby, I am also interested in what John has to say with running such high compression and high boost. Obviously E85 makes it better but how much timing realistically would you be able to run with close to 10:1 static comp and 50psi boost?
What is the deck height and head gasket thickness?
I will let bobby answer for sure, but I would say modification of the combustion chamber and piston would allow this.
Hi all,
First 49psi Turbo side after the intercooler this will be 34psi.
The deck height info i will find out and let you know.
The head gasket thickness is 1mm.
We can run alot more advanced timing then any other normal engine.
Why is it we cant run advanced timing in other motors as that they start to detonate. Because they need so much fuel to keep the chamber cool and soon as you put more timing in then detonate. To avoid this problem you need the correct selection of cams and the correct lift we this is why we can run this high comp.
Head has standard valves with custom pistons and no chamber has been changed nor has the port been opened up. The key is squish you can run more timing and you can lean mixtures and minimise detonation.
John in tha past has tunned alot of V8 and tuned them to 14.1 AFR under load and still making power this is not heard of, any tunner will say that is too lean under load and will blow the motor.
I will still ask john the question i will have to record it on my phone the answer as he will not do a video 8(.
Wow this thread turned into somthing veery different than the first page...
People forgett that the last 10 or 15% of potential usually takes up 80% of the resources (time/money/material etc) to achieve. I'm diggin the process and I hope to see more of how things were calculated, planned, fabricated etc.
Also, the r and d that goes/wen't into most of the off the shelf products we buy to 'bolt on' had alot more than 10k invested before production- per piece!
Good luck and keep us posted!!
Cheers
Justin
Just got confirmation Deck height is 7 thou with a 1mm headgasket.
I'd like to have a chat to your builder John about what he is doing with this setup. Ive read a lot about optimising the squish area of the combstion chambers, and specially designed "squishy" pistons that aim to compress the air fuel charge into the perfectly shaped combustion chamber and maintaining a high compression ratio at the same time. Like all hot-rodding idea's concepts arent new, but at the same time they arent common either as it takes time and skill to setup the engine properly.
The information I read about it was relating to SB Chev's and nascar in the 80's. To a degree the RB26 in stock form does apply some of the concepts, but in reality as a mass production engine they arent all perfect or 100% identical by any means. Most blocks have un-even deck heights from factory.
Im guessing that is a 7 thou positive deck, which will mean that with an un-compressible 1mm metal head gasket he is aiming for around 33 thou head to piston clearance which is about as close as anyone would dare. Especially when you factor in the big HP nature of the engine and that to do so you will be running much larger than stock clearences on the crank and rods. It will be interesting to see what kind of rods you use as well, because when things are setup with working clearances being this close, even thermal material expansion can ruin your day. Im thinking they will be titanium.
Well you are more then welcome to speak to john however he does not speak to anyone on the phone, the only way you would be able to speak to him is in person and he has no problem in speaking to anyone face to face.
What you have said about the Nascars is correct squish applies to any piston motor even a 2 stroke john setup, my 2 stroke jet motor and let me tell you the thing is like no other with the squish closed up it makes more power then any other 2 stroke motor and uses less fuel then standard, the guy tuning it could not understand !!!.
Getting back the RB you are correct 7thou Positive Deack 1mm head gasket equates to 33thou piston to head clearance. Regarding the clearance for the rods and crank i will have to find out. The crank i am using is a Z-tune stroker crank with crower conrods.
the guy tuning it could not understand????????who was that?anyone that has half an idea with twostrokes knows that most if not all original squish bands on two strokes (even competition off the shelf high revving mx bikes)have an excessive squish from the factory.......one of the first things we did since i was a kid was bubble gum the piston crown on our brand new never started race bikes and tighten up the squish.....sometimes we welded the chamber and changed the angle/width.... the changes had dramatic effects on the lower end power/response.....generally the larger the engine the bigger gap they had/require for instance with say a kx80 engines we used around .7 and kx500/cr500 around 1mm this obviously has many variables such as which fuel is used....sometimes we had diffrent head/cylinder/chamber combo's for diffrent tracks.....nice job by the way.....good to see someone putting in attention to detail :thumbsup:
Edited by ylwgtr2
This was on a waveblaster with a 800cc bore with the lot billet crank forged pistons billet head nd so on. Oh this is a 93 model design so its very old. The squish was like 1.1 mm huge john remade the cup's closed it down not sure what he closed it down. The guy tunning had build so many waveblasters and tunned many of them when he went to tune this one it used smaller jets then a standard ski. As you can see now the later design 2stroke have that close squish.
This ski could only be run on avgas previously now i can run it on 98RON its one crazy ski.
im not sure about marine stuff as we only play with dirt/road race bikes here....and there isnt a huge range of twostrokes anymore mainly KTM's and i dont work on those at all....of late we been trying to keep the twostrokes alive by fitting cr500/kx500 engines to the klx/kxf/crf
range...i say fu(k the whales.....save the two strokes!
Marine and boke not much difference i like to hear that your keeping something old alive um something to let you know i remember i guy who John knows he had a 500cc 2 stroke he currently hold the fastest land speed please dont quote me i think he raced his 2 stroke im trying to remember his name but yeah go the 2 stroke.
Below is a pic of the Fuel cooler. This is setup on the return line as we didnt want heated fuel to go back in to the surge tank.
Its very important that fuel temp is watched when using E85 as the expansion is 10 times greater then normal fuel. This can cause a dramatic change in the AFR, example if you tuned your car on a hot day now when you drive on a cold day, it will run lean. Now if you have tuned it on a cold day now on a hot day it will run rich. Basically your fuel pressure can vary.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
