This build has not finished, alot more to come and i will try to update it on here and facebook.
currently waiting on motec for a revised Gpr package to run the Hi lo injection properly and also need some other setups to be completed.
Once i have the car running on M150 we can then start a new chapter on tuning and i know this will piss off alot of tuners out there lol.
Anyhow keep reading and learning as there is much more to come.
  • Like 3
  • 2 months later...
Yeah, I would love to see a dyno sheet and a boost curve for this.
It's an awesome build with some seriously cool hand made manifold and wastegate piping, I too am a little surprised to see a T70/T72 turbo mixed with the work of art parts around it, it's sorta like two steps forward and one step back when there are some much better technology turbos out there now.
......but I would love to be proven wrong :)
  • 4 months later...
  • 2 months later...
:/ wonder what ever happened to this build....
was super keen to see results but Im assuming its all fell short?? there aren't many high HP RB26 builds that seem to be able to successfully run a MoTec.
An ecu is only as good as the calibrator in most cases unless its 20year old technology.
  • Like 1
  • 4 weeks later...
  • 3 months later...
  • 4 weeks later...
Hear someone went to the big house for modifying things that go boom, boom... that might slow down progress perhaps?
Explain
If you are referring to Bobby you must be wrong as he is still quite active on Facebook. In fact he was actually taking the car out today
  • Like 1
Meh....the reality is that the car must have fallen short of expectations
Really not sure how a full tune can drag out for 2 years... so claims that the build was f1 spec, just musn't show on the dyno graphs
there, i said it.
/thread.
  • Like 4
  • 2 months later...
You guys are all funny , you need to follow me on FB i dont get on here as much anymore!!!!
Been busy with large projects and i have managed to get the car sorted for its final tune, Chris from motec will be doing the final config as he has been away in USA.
So once the config is correct and the car responds, it will hit the dyno straight after that.
BTW the car drives perfect and the VENTURI works !!!!!
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
