sikaflex... lots of sikaflex
oh really... hmmm they look cool but sikaflex to hold it on is a tad annoying...
did you install yourself?? and were you worried the first few times you took it for a drive?
blags roof spoiler looks like it mounts outside of the glass area?
Anyone want to confirm there are two different roof spoiler types out there?
blags' old one is a falcon unit that he made fit... he now has one the same as mine.
Does this help with aerodynamics ?, whats it do ?, is there proof ?, or is it just for looks ?, if it helps aero I also may be interested.
Sorry for the hijack
Mark
helps with aero street cred... ;)
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
