Hey all,
Well Ive got most of my parts for my work ready and it should see anything from 280 - 310rwkw on regular fuel pump. The next thing to consider is my brakes but wow the price figures on a set of big brakes is amazing.
I'm going to be cheap here and ask for help and opinions.
First off. What is the biggest, safest size I can get for 17" wheels? Do aftermarket brakes bulge out more than the Nissan brakes on the R33 GTST? They look alot slimmer in pictures.
Secondly, and a big secondly. It looks like alot of money can be saved if I ditch the rear brakes. I can understand this would have a huge impact on a AWD car but all rear wheel cars, including skylines, have little tiny brakes at the back and bigger up front. If I upgrade just the front brakes, would I still get even braking? I don't want my ass to shoot left and right.
Secondly, has anyone heard of the following brands D2 or KSport?
D2 have an 8 piston front caliper, rotor, lines, pads, bolts and adapter set for an R33 for $1650 shipped. KSport have a 6 piston front set for $1500~
I don't really like the idea of running 10 - 15 year old GTR brakes when something brand new can be had for roughly the same price(seriously those old GTR brakes are too overpriced).
Any input would be great.
If anyone can recommend anything else, I ask for your suggestion!
Cheers.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/356186-changing-only-front-calipersrotors/
yes obviously 8pot brakes will be bigger than factory brakes, Keep in mind the rotors are big on those big brake kits that why they prob look slimmer in pics.
It depneds on the disk type and offset of your 17's. I would assume you would be fine upgrading the front brakes and leaving the rear standard and not having too much ill affect.
Yes everyone heard of d2 and ksport do i quick google search for reviews.
GTR brakes are proven quality and priced accordingly. Mind you like anything second hand with imports some ppl want drug money for their parts.
Edited by Omg_its_trent
whats the intended usage of the car? Power is sort of irrelevant as a track car would have more of a need for better brakes than a street car sitting on 60 all day.
Keep in mind nissan did a good job with the brakes, look at brembo factory calipers maybe as a good upgrade before spending big $ on the biggest and best only to be let down by worn bushes, and poor rubber on the tyres.
Around the 330mm mark seems to be a safe bet with 17" wheels. Really depends on the wheel design whether it will clear the brakes as the caliper is now being moved closer to the edge which is where certain wheels will start to "curve in" so to speak.
This all comes down to brake bias. The front usually has a lot more bias since it does most of the work hence why rear brake calipers are a lot smaller. Obviously there is a lot more to this but I won't cover it here. Research how brakes actually function on the net to get a good understanding of it all.
So as long as you don't upset this brake bias to much you can easily upgrade just the fronts and have the factory rears work in harmony. If you do change the brake bias this can also be ok if you know what you are doing and set it up accordingly.
These brands are all the same. They are manufactured in China and can go under a lot of different names. Basically I could put 100 kits into manufacturing and call them G SPOT and bring them out.
There have been a lot of positive things said about these kits and are probably the most affordable aftermarket options. I looked into these myself but at the end of the day just didn't feel all that comfortable with them.
I know exactly how you feel. The GTR Brembos are great brakes. Perfect bolt on, 100% legal with no mod plates etc needed. However the money people ask for them given their age is a joke. If they were realistic money this would have been my upgrade. Sometimes you can get a bargain, but I was never lucky enough.
Well basically after everything was looked into I chose to go with the Wilwood kits that I put together for our group buy. They were everything I wanted in a brake package and were a decent price. For $1850 delivered I really don't think there was anything that could match them :)
My 2 cents.
I'm running the ksport 8pot 330's on the front with stocker 33 gtst brakes on the rear.
blue stuff up front with yellow stuff on the rear. One track day down, no problems.
fitment with 17" depends on the rim. RPF1 will not fit. super advan, te37, gramlight will.
For performance, Personally Id just upgrade to some decent discs like dba 4000 and a quality set of pads like the QFMs , a set of braided hoses and maybe motul 6100 fluid ,I reckon you'd find the setup more than adequate for most applications and cost well under a grand all up..
That said, big brakes do look cool, But Im a cheap ass :P
Hahaha slacker :P
Nah still waiting on the Wilwoods. Maybe another 2 or so weeks.
I'm looking forward to getting some money to put semi slicks on the car to really get the benefit of the bigger brakes.
4000's will crack on the track. I've gone through a set as have many others (Calder, PI and Sandown)
rda, dba5000's, pmu single's in 324mm with UAS spacers is the other thing you can go. I did, but you chew through pad's.
On my 32 I run 33gtst calipers on dogbones to fit 324mm (33gtr) DBA4000 rotors, DS2500 pads, braided lines and a master cyl stopper.
Way more braking than street tyres can handle (haven't run full slicks so can't comment on that).
They BARELY fit under 34GTT rims, there was like 1mm of clearance from outside of caliper to inside of wheel.
I'm keen to try out a big brake kit on my car.
I'm actually running the setup couple of guys have mentioned being the dba4000s, pads (i'm using project mu pads atm), steel lines and high temp fluid but i still find the braking lacking. Tires are KU36s which as some may know, gives insane grip in the dry for an S compound. Hope this feedback helps.
For the street GTT or GTR brakes with Motul (or other quality) fluid and decent pads will be more than adequate. Just bought a set of D2 fronts for the track and although they have a good rep for stopping they are not going to do my unsprung weight any favours!!
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
