testing would be good. i will also have a look at my ariel connections but i used foil and tape to seperate the core and the netting.
Did you run power to the antenna? If you did not your antenna are not powered as they are designed to be. The standard set up only runs power to the antenna when the TV is selected. When you select the AUX input it turns the antenna power off.
Cheers
Andy
  • Replies 144
ok so i realised i didnt understand what andy was saying with the power so i spent the afternoon pulling apart my boot again and running seperate power supply cables to the 2 factory clarion antenna boxes. This works a treat now so when the DVB-T unit is powered up so is the ariels. I also found out the when the Tv board is out of the Gold Casing that it works 100% better (Found this out due to testing when i had to solder the antenna IN back onto the board, totally my doing. IE- dont over tight the ring nuts on these sockets) So i just used double sided tape and put it on the inside of the rear quarterpanel near the original unit.
Commsman- Thank you for all your help with this install. Your information has been spot on and i thank you for that. Also do worry about sending the other unit for testing as i feel confident that i have got it to work as its ment to this time.
  • 1 month later...
Newb question.
Is one of these the TV tuner?
I know one of them is the ECU :D
None of those. You are looking in the wrong end of the car.
TV tuner is behind the rear left panel in the boot. Just in front of the little storage box.
Cheers
Andy
May I ask what aerials you guys are using for your digital TV's.... Ive got a digital tuner built into my head unit but the aerial its supplied with is a passive (un powered) jobby that doesnt really get very good reception while in motion or anything.
Cheers
Cheers
Any of the M35 Stagea's are using the Factory aerials in the back windows (4 in total) as they are powered and very effective.
The new Digital HD tV tuner from Leon come with a pair of powered aerials. See if you can persuade to sell you a pair of unused ones.
Cheers
Andy
Hi Chris. The ones that come with these new tuners have F-type connectors & a wire for 12V to amplify the signal. They seem to work well.
Anyone with a Stagea who bought a tuner recently from me/Andy/Brad should have the aerials spare. If you can't find anyone nearby, I should have at least one spare pair which you can have if you pay post & packing (say $15) if that will help.
Cheers, Leon.
It seems that they work best with maximum separation. Since these are almost always used in non Stagea cars (V35's etc), most people stick one behind the passenger sun visor & the other on the back windscreen on drivers' side.
In your case you may want to try behind passenger visor and maybe run the other to the drivers side fixed window at the back (probably not the tailgate :glare: ). With dark tinting they would be hard to see from outside.
They have a sticky surface to hold them to glass which appears to be OK. No one has told me they had any problems. There is adhesive you can get if they lose their 'sticky' I suppose.
Want to pm me your bank details?
the connection in the back of my head unit only takes one antenna.... :S What would you suggest?
Could you put up a picture of the plug with a 5c piece for size comparison too :-)
I would suggest that one antenna won't pick up a TV signal very well, LOL
The connectors are F-type (you can google that) which means they have a screw in fitting. About the only other connector you commonly see is PAL (std TV type). There are adaptors to go from one to the other (I have some) but then space can become an issue behind the unit. Maybe a right angle adaptor could work tho....
Do you have a spare AV input (RCA connectors)? If so, if the single aerial doesn't work you could always go for a new digital tuner plugged into a spare AUX input :whistling: .
  • 2 months later...
Can you play your iPhone through this tuner via the usb input?
I doubt it will work conveniently like that (mainly designed to play files using remote & file manager style inteface). However, the AV input (with RCA connectors) will work nicely using the right lead to connect to your device. And with some thought & a few relays you could run both reverse cam & Ipod/MP3 as inputs, or maybe a DVD player, PS3 etc etc.
But please post up what you find as there's heaps of variations I've not tried nor thought thru how they could work.
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
