testing would be good. i will also have a look at my ariel connections but i used foil and tape to seperate the core and the netting.
Did you run power to the antenna? If you did not your antenna are not powered as they are designed to be. The standard set up only runs power to the antenna when the TV is selected. When you select the AUX input it turns the antenna power off.
Cheers
Andy
  • Replies 144
ok so i realised i didnt understand what andy was saying with the power so i spent the afternoon pulling apart my boot again and running seperate power supply cables to the 2 factory clarion antenna boxes. This works a treat now so when the DVB-T unit is powered up so is the ariels. I also found out the when the Tv board is out of the Gold Casing that it works 100% better (Found this out due to testing when i had to solder the antenna IN back onto the board, totally my doing. IE- dont over tight the ring nuts on these sockets) So i just used double sided tape and put it on the inside of the rear quarterpanel near the original unit.
Commsman- Thank you for all your help with this install. Your information has been spot on and i thank you for that. Also do worry about sending the other unit for testing as i feel confident that i have got it to work as its ment to this time.
  • 1 month later...
Newb question.
Is one of these the TV tuner?
I know one of them is the ECU :D
None of those. You are looking in the wrong end of the car.
TV tuner is behind the rear left panel in the boot. Just in front of the little storage box.
Cheers
Andy
May I ask what aerials you guys are using for your digital TV's.... Ive got a digital tuner built into my head unit but the aerial its supplied with is a passive (un powered) jobby that doesnt really get very good reception while in motion or anything.
Cheers
Cheers
Any of the M35 Stagea's are using the Factory aerials in the back windows (4 in total) as they are powered and very effective.
The new Digital HD tV tuner from Leon come with a pair of powered aerials. See if you can persuade to sell you a pair of unused ones.
Cheers
Andy
Hi Chris. The ones that come with these new tuners have F-type connectors & a wire for 12V to amplify the signal. They seem to work well.
Anyone with a Stagea who bought a tuner recently from me/Andy/Brad should have the aerials spare. If you can't find anyone nearby, I should have at least one spare pair which you can have if you pay post & packing (say $15) if that will help.
Cheers, Leon.
It seems that they work best with maximum separation. Since these are almost always used in non Stagea cars (V35's etc), most people stick one behind the passenger sun visor & the other on the back windscreen on drivers' side.
In your case you may want to try behind passenger visor and maybe run the other to the drivers side fixed window at the back (probably not the tailgate :glare: ). With dark tinting they would be hard to see from outside.
They have a sticky surface to hold them to glass which appears to be OK. No one has told me they had any problems. There is adhesive you can get if they lose their 'sticky' I suppose.
Want to pm me your bank details?
the connection in the back of my head unit only takes one antenna.... :S What would you suggest?
Could you put up a picture of the plug with a 5c piece for size comparison too :-)
I would suggest that one antenna won't pick up a TV signal very well, LOL
The connectors are F-type (you can google that) which means they have a screw in fitting. About the only other connector you commonly see is PAL (std TV type). There are adaptors to go from one to the other (I have some) but then space can become an issue behind the unit. Maybe a right angle adaptor could work tho....
Do you have a spare AV input (RCA connectors)? If so, if the single aerial doesn't work you could always go for a new digital tuner plugged into a spare AUX input :whistling: .
  • 2 months later...
Can you play your iPhone through this tuner via the usb input?
I doubt it will work conveniently like that (mainly designed to play files using remote & file manager style inteface). However, the AV input (with RCA connectors) will work nicely using the right lead to connect to your device. And with some thought & a few relays you could run both reverse cam & Ipod/MP3 as inputs, or maybe a DVD player, PS3 etc etc.
But please post up what you find as there's heaps of variations I've not tried nor thought thru how they could work.
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
