Hey all,
Well this has been baffling me a little and I don't know if its normal or not.
Anyway, Ive got a relatively stock R33(exhaust, fmic, 10psi, ecu). Ive noticed that first gear up to about 4500 - 5400 is best. Anything above 5400 rpm does not seem to do anything. Is this right. I hit about 59 - 61km in first gear by 5300rpm then the rest til red line is just noise with no speed gain, torque or power. Is this right? I never noticed this with my old R33 as by the time I got to 4000 id hit 7krpm in no time and be out of the gear. I find its best just to get out of the gear at about 5krpm.
This is the data I got about gear ratios and speeds per gear.
RPM 1st Gear 2nd Gear 3rd Gear 4th Gear 5th Gear 6th Gear 500357912-100059131823-1500814202635-20001118273547-25001423344458-30001627405370-35001932476182-40002236547093-450025416179105-500027456788116-550030507496128-6000335581105140-6500355987114151-7000386494123163-75004168101131175-80004473108140186-85004677114149198-90004982121158210-95005286128166221-100005491134175233-
My tyres are 245/45/R17. According this this chart I should hit the speed I recall by redline.
My next question is raising the rev limiter. Is this as simple as using my PFC hand controller and raising the limit to say 7500? Would this give allow me to hit the above speed of 65km/h?
https://www.sau.com.au/forums/topic/356295-top-speed-per-gear-is-this-right/
ummmm..... If your car is reving more and not gaining any speed what does that tell you?
Make sure your clutch isnt slipping
If your engine is still increasing speed then your gearbox should be increasing speed.... Raising the rev limiter is not going to fix this. Think about it.....
Could it be that in the top end of the gear say from 5400rpm to 6500rpm the speed gain is very small?
Ive smelt my clutch before and believe me this isn't one of those stink free clutch. Its also a relatively fresh clutch.
You have to think about how a car works. Hopefully with this explanation you can understand:
PHIL'S RPM EXPLANATION
Say an engine spins at 1000rpm. This means the flywheel is spinning at 1000rpm. This is the RPM that you are seeing on your tacho.
Now say you are in 4th gear with a gear ratio of 1:1. This means that the driveshaft coming out of the gearbox is spinning at 1000rpm.
Say your final drive ratio in your diff is 4:1. This means that the wheels are turning at 250rpm.
So as you can see, if you simply increase the engine rpm to 2000rpm and keep everything the same, the wheels would now be spinning at 500rpm.
Increase the engine rpm to 4000rpm and now the wheels are spinning at 1000rpm.
See how there is a constant relationship? It doesn't matter how much power the car has, the speed always remains at a constant relationship since it is simply being multiplied by gearing. The thing that power alters is how quickly - acceleration - it gets to the higher RPM.
So if a 100HP car does 100km/h at 3000rpm and 130 km/h at 4000rpm. That same car with a power increase to 400HP will still do 100km/h at 3000rpm and 130 km/h at 4000rpm.
This is a very rough and basic explanation but it is ment to show you the relationship of engine RPM and wheel RPM. It is a fixed relationship that always has to stay the same.
So to answer your question, no. The end of a gear from 5400rpm to 6500rpm will still be giving the same constant linear increase in speed.
  • Like 2
Woah, how are you hitting 59-61 kph at 5300rpm and im only able to hit 50 kph by 7000rmp?
Didnt think series 1 and 2 were that different lol.
I've got a series 2 and can only do about 50-55kph at 7k rpm as well?
Edited by Dani Boi
I really don't know. Coming up the road earlier today, I was just sitting there watching my KM sit at about 58 and the revs increase.
I already understand the concept of how things work in relation to speed of engine to the wheels vs power is how quickly you get through the gear.
Ill take it out for a quick boot and check what shits what. Ill do it safely though, rather that watch the cluster Ill just use my hand controller to record the max data logged by the end of the gear, the clear it then try it to 6krpm, then clear it, 5krpm. ill get an indication of where this shits at.
Use the graph on the hand controller to see if the speed peaks then holds while the revs increase. Log speed and rpm and then click next twice and it should get you to the graph
This is if you have a power fc. That's what I was guessing
Could also be a lagging tacho, i.e. you're hitting 7000 when it says 5000...
Ordinarily I would say slipping clutch, but I have experienced similar issues with mine. My tacho goes friggen wired between 3000 and 4500...just shoots up almost instantly, but outside of that range it works perfectly fine.
If you can actually hear/feel your engine increasing speed though, then the speedo drive / dash is buggered. Car will feel like you've hit a brick wall in terms of power after a certain RPM.
Thats tru to.. But I guess he should be able to hear the limiter if its actually reving alot higher then it is. Hard to say
Maybe try a new tacho, and if you have a power fc, graph speed vs rpm on there (as I described above) and see if you can see the revs continue to rise when the speed has flattened
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
