I think the point is that Zubra appeared to knock the car's startline performance notwithstanding the fact that it was the first time out. If I had spent such long hours, huge effort and ot to mention a load of money on such a car, I too would be taking it easy launching it on the first pass, if not the first couple of meets. The mention of PRO TREE has absolutely no relevance as this was effectively a 'shake-down' pass. But some people like to be the ultimate wiseguys. Leave it for the wasteland.
I am sure that with a few more passes under its belt and when it gets to a Pro tree race it will be sorted - as with almost all new chassis' and engine combinations - it takes time and trial & error to get a car of this calibre tuned to do what it needs to do.
Actually, while Im on the subject of Sport Compact Drag classes, what are the rules re: 2 power adders? eg n2o and a Turbo, its not allowed for the V8 guys, is sport compact any different...been a few years since I looked through the Andra Rule book.
zuboora bi temak :whistling:
  • 1 month later...
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
