  • Replies 61
i am well aware that there are faster cars out there, i just want something that can go moderately fast and skylines do the trick for that amount of money i put in. also i like the look of the skyline so i'm happy, in addition, i have already bought the car so no use crying over spilt milk.
so it seems that it will do it in 8 seconds, thanks for you help guys!
https://www.sau.com.au/forums/topic/356793-0-100-kmh-time/#findComment-5708048
I'd like to see 8 seconds flat on a G tech timer with a standard N/A...won't happen...and if it does, you'll have to be bang on the mark with launch and gear change. It'll be closer to 9 on average. Still decent for a daily driver but don't expect to be beating Commodores and Falcons unless they are shit drivers.
https://www.sau.com.au/forums/topic/356793-0-100-kmh-time/#findComment-5708539
all irrelevant. unless your going below 6.5 seconds it all feels the same anyways. the difference between 8 and 9 seconds is nothing on the road......only on paper, or if you cant count. just enjoy it, and get a turbo one when you can :thumbsup:
https://www.sau.com.au/forums/topic/356793-0-100-kmh-time/#findComment-5711612
Duno about that, my n/a just had a catback exhaust and smashed fords and holdens with exhausts, dynoed at 123 rwkw
Depends if you get a clean example.
https://www.sau.com.au/forums/topic/356793-0-100-kmh-time/#findComment-5712798
id bring this back to the key issues people so often overlook- tyres n suspension
yeah with stock tyres n suspension id agree with those sad times for both de & DET.
throw some decent rims n tyres at em and even suspension (my 33 DE had this) n it is considerably quicker. Go to the drags, its all about getting that power down quickly.
https://www.sau.com.au/forums/topic/356793-0-100-kmh-time/#findComment-5712927
my mates R33 does it in 6.8 (shitty timing skills but wouldn't be much over 7secs) his car is freaky tho :S he bought it off a guy who knew NOTHING about it.. however it had 2k worth of suspension upgrades and some wheels on there so never know the previous owner might have done something performance wise...
on the other hand my N/A r34 GT with an ecu and tune does it in 7.7 secs so far with a average launch but not the worst. so i'd say around 8-9 for a stock one
https://www.sau.com.au/forums/topic/356793-0-100-kmh-time/#findComment-5720156
    • Yea that's a fair assumption. I'm presuming they call them solid lifters as they have no moving parts like hydro lifters.
    • I believe you're confusing WMI with water injection. Looking at that graph, the 93aki+WMI car is making more power than C16 race gas. Boost juice, which is what I also run, is Snow Performances 50/50 premix.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
