Hey guys
Im currently looking at a AU XR8 manual as a tow car for my 32 and for the misses to drive during the week.
I was just wondering if any one up there has owned one and had any problems?
Or if theres any comman faults i should be on the lookout for?
I test drove it today and for a car thats done 210,000kms i was pretty impressed with the feel of the engine and driveline.
Any input would be much appreciated.
Thanks
https://www.sau.com.au/forums/topic/357250-au-xr8/
They use lots of fuel....
You want one of these (at a really good price too...)
http://www.carsales.com.au/all-cars/dealer/details.aspx?R=9509282&__Qpb=true&Cr=1&__Ns=pCar_RankSort_Int32|1||pCar_PriceSort_Decimal|1||pCar_Make_String|0||pCar_Model_String|0&keywords=&__N=1216%201247%201252%201282%204294967079%20903%20408%204294966839&SearchAction=N&silo=1011&PriceTo=408&seot=1&__Nne=15&trecs=7&__sid=12CB54BF3AF7
Not bias or anything......
I LOVE BMWs! FWIW, my mum has a 528i E39 and I've managed 6.2L/100km out of it ;) ^V8 so good for towing I guess lol.
Edited by Ten Four
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5712267
^ ^ ^ So long as that 535i has had all its services done properly, it's a bargain.
I'd check fault codes and fluid leaks re side tanks, water pump, oil. Electronic digital cluster can degrade over time.
Even as a V8, the beemer uses much less fuel than the XR8 and the E39 cornering ability is renowned
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5712511
If you are going to use it for towing, get an auto.
Braked tow capacity for a manual is nearly half of what an auto is rated for.
And yes they are thirsty, it cost me $140 in fuel to go from Sydney with the trailer to Newcastle then back with the car on.
On average about $120 a week in fuel to run. We use premium though.
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5712547
Mmmmm......yeah get a beemer, casue like, it'll be super cheap to fix when things start wearing out prematurely because you've been using it as a tow vehicle.
Hell, the extra $12 million dollars it will cost to maintain a beemer will be more than offset by the $15 per week saving in petrol you are bound to make.
Wait, I've just re-read you OP and realised you didn't ask for an alternative to an AU XR8. Silly me.
The AUs are bullet proof and pretty much perfect for what you want. Any vehicle capable of towing another vehicle frequently without collapsing in a heap is going to use a bit more juice than the rest as it's A) Heavier - to deal with the extra stress of towing and B) going to have a bigger motor.
As long as the AU has been looked after you shouldn't have any issues.
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5712581
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5712663
Win!
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5712716
Which series is it? Is it a series 1 XR8? If you can, try to go for a later model with the 220KW engine.
The mechanicals of the AUs are pretty reliable, but the interior quality can degrade quite heavily over time. Also, some of the smaller things like the electriconics can be unreliable. I've known of several AU owners (including my dad) who had constant problems with the radio, electric windows and mirrors and some of the engine management electronics. But I guess any used car would have these problems.
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5713946
My dad had similar issues to those on his au.
I was looking at them a while ago. The basic 5.0 L engine isn't much more powerful (13kW) or torquey (32Nm) than the xr6 at the time. And, worst of all, made at about the same rpm. It certainly felt pretty slow and heavy, despite extractors and twin 3" exhausts (well, felt and WAS slow and heavy). Getting out of the r34 and straight into it didn't help though.
(Source: http://www.trueblueford.com/AU_XR_Specifications.html )
When I was looking at them the problem that kept coming up was a whining diff, which needed some pin replaced, can't remember how much it was. Certainly wasn't cheap. I also found the pedals sticky and numb, not smooth like in almost every japanese car I've driven.
All that said though, it's a lot of car for the dough and the noise was fantastic!!! Also cheap to fix and your average mechanic is capable of working on it.
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5714149
Bit of a tangent here, but on the question of what feels faster, a torquey, low revving V8 will often feel slower than a high revving turbo 6 as it makes power everywhere which means no "coming on boost" which can often give the false impression of speed.
My mate has an SII BA XR8 and it's almost neck and neck between it and my R33 GTST (mine is ever so fractionally faster in a straight line) however the R33 feels much faster. I remember the first time I took him for a spin in it his head nearly exploded as he thought it was so damn fast. Fact is, it's not much different to his car, and he flogs his thing everywhere. It's just his thing makes pwer from idle so lacks that kick in the pants feel that pretty much everyone on here is likely addicted to.
So while something like an XR8 may feel a lot slower than something like a turbo skyline, fact is there's probably a lot less between them than you think. And when it comes to corners, it's about 70% driver 30% car so a good steerer in an XR8 will likely spank a nubcake in a skyline.
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5714459
I agree with the cowboy above, but I was also watching the speedo and there was a big difference between it and the r34 (running on 12-13 psi with exhaust, nothing too fancy). In terms of feel it felt slower than my current magna, but i don't think that was the case.
Also, unless I'm mistaken, the ba v8 was a crapload better than the au. The numbers on the au xr8 over the xr6 arent great for the au:
xr6
172 kW @ 5000 rpm
370 Nm @ 3500 rpm
xr8
185 kW @ 4600 rpm
412 Nm @ 3500 rpm
I'd go the xr6. Actually I would and did go magna. Not sure how it'd go towing a car though. There was a towcar thread on here a little while ago that in a nutshell strongly recommended people buy big 4wds so that the 2 tonnes of gear following can be kept under control.
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5714499
I recall the time that the AU XR8's were running out, Ford were doing some interesting stuff with them. One of the car magazines put one on the dyno and it nearly made the flywheel ppower figure at the wheels. Apparently they were using roller rockers and other goodies in these engines to try and catch the 5.7 Holdens, even though the marketing department never made a lot of noise about it.
As others have said, they are pretty rugged, no nonsense cars that are generally good value for money. They'll never impress euro or jap import snobs, but you do get a fair bit of car for the money.
The unreliable electrics seems to be common in Falcons. Mine had to have the following replaced under warranty: ECU, Central locking computer, power mirrors and power door lock actuators (twice). Each time I took it in for a complaint, the response was "yeh, they all do that" >_<
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5714546
Au Fords were actually very mechanically sound. You shouldn't have many problems with it, mechanically that is - It had the lowest warranty issues of all family sedans during it's time (even less than the Toyota Camry and unlike the VT, which had the highest warranty issues.)
Their manual gearbox is also unbreakable. Power-wise the au S1 and 2 left much to be desired. at ~175kw The s3 on the other hand was 220kw. Torque was awesome though so for towing you shouldn't have a problem.
If it's for a good price as you say, then go for it.
https://www.sau.com.au/forums/topic/357250-au-xr8/#findComment-5714614
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
