Hi guys, I've just bought a bare Aero front bar for my Stag, and was looking to buy the plastic Spotlight Blanking Plates in the aperture of the bar from Nissan.
The problem is; The version of FAST my local dealer has, doesn't list any part numbers for the aero kit. My Nissan guy suggested it might be bacause it's an acessory option, and these don't appear on their system.
Can anyone find the Aero pieces on a different version of FAST? And if yes, can you tell me what the part numbers for the blanking plates are?
Cheers, Dale.
https://www.sau.com.au/forums/topic/357366-nm35-stagea-aero-bar-fast-numbers/
  • Replies 64
Posted Images
is this a nismo option??
I can look up accessories fairly easily at te shop but i need to know what I am looking for. do you have an area/ref figure I can dig into?
Chris, it's not a Nismo option. There was a Nismo option bar, but this is just the "Aero Selection" part. Basically, the bar came with driving lights or without, there were just simple black blanking plates. I'm assuming the lights will be heartstoppingly expensive, so I'd rather go with the blanking plates.
A couple of the guys have posted up catalogues, and I've just found the relevant catalogue; http://www.skylinesa..._1#entry4911158
Is there enough info in those two pics to get an idea?
Cheers, Dale.
sorry for hacking your thread
But if I want an Axis front bar + grill for my ARX - Do I need to change my bonnet?
No, but you will need the chrome decoration on the indent in the bonnet, above the grille aperture.
My Euro has that chrome thing on the bonnet - and the bonnet have that indent to clip this chrome
so basically I need to look for an AXIS bonnet then? cause how will I clip/install the chrome garnish?
Good call, I assumed the bonnet was the same; didn't even know there was a different one for S1 m35s, just with a strip to hide the indent.
Looks like we need an AXIS owner to weigh in...
Edited by Daleo
Since I now have an M35 with an aero bar, I don't suppose the numbers are printed on it?
I don't have blanking plates though but the foggies are just Cibie, I would think they're a standard size?
If you feel like having a look that'd be great! What's the bet any part number is blocked by the Reo...:whistling:
Perhaps running the VIN from a car with the Aero Selection Bar/Kit through FAST will reveal the part number? I don't really know if FAST works that way.
I may end up having to make something, I guess time will tell.
Edited by Daleo
I have the original m35 parts book at home and know it includes part numbers for options as well. Will check it out for you but won't be able to until tomorrow. I posted the scans of the brochures as you showed above and also have some other paperwork m35 option related, so I'll see what I can find for you
I have also heard the foglights are identical to Nissan cube however have not confirmed. May be worth a yahoo jp search to see if this is correct or if I had the part number for the cube foggies could cross reference it to the M35 aero ones.
Will see what I can find.
Well I can help with that too, if you want I can give you my VIN to put through FAST?
Rear Aero bar is a bitch to clean though, the little 'shelf' on the back bumper is annoying!
Very interesting points you make.:thumbsup:
Thanks to both of you fella's, really appreciate the help!:worship:
K6020-AQ003 is the number for the front bar, but it looks like the plates etc are "all in one" with the front bar and ducts (section F20-001 if your Nissan guy needs to know)
Edited by iamhe77
Sorry for hacking again
real quick question
so If I want to change my front bar ARX to an AXIS - can I just leave the grill stock? or Do I need to change grill to fit it in?
Is this straight bolt on?
real quick question
Different Grille, different aperture shape in AXIS bar.
Looks like I've hit a wall.:/
I used all the numbers that everyone has kindly given, and my parts guy Chris, at Nepean Motor Group, has turned out to be quite the FAST guru! The system seems to be just menus, hidden inside menus, hidden inside menus...
The numbers did eventually lead us somewhere.
We were able to track the Aero Bar to the point where a complete bar could be ordered ($2500!) but we weren't able to find a breakdown of the individual parts that make up the bar. It also din't show the optional driving lights in the front bar. It also appear that when you order the bar it comes colour matched.
The biggest issue that stopped us in the end, was the language barrier. There's a lot of japanese text that could possibly provide more info, but we simply didn't know.
So unless I can find the bits somehow on Yahoo auctions or IM, I think this ride is over.
And if you have one; TAKE CARE OF IT!
Thanks again to everyone for you assistance :thumbsup: .
Cheers, Dale.
Edited by Daleo
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
