  • Replies 184
Posted Images
Looking good!
Love the dimple dies, I want some!
Cheers :) its getting there, just cant wait to drive it around again - but i know you know that feeling lol
ebay search the following to get the set i got : 7pc 4140 Dimple Die Set (#160548222631)
Chris the car looks fantastic,,,you have sold me on those wheels,,,they suit the car perfectly. Screw the weight thats the wheels I'm buying.
Two questions if I may though
You use a circular saw to cut aluminium,,,never entered my head,,,I always use a jigsaw which is a pain in the arse. Do you use a particular blade???.
The dimpling tool I've always wanted,,,I would only ever use it on aluminum and it seems for best results I need a press. Is there another way of doing it or should I wait and make Mr Handley buy a press?.
Cheers
Neil.
Neil,
TECHNICALLY you need a different blade - that saw is using a regular old wood blade :P spray it with inox and away you go :D
i have a table saw with the proper blade, but the brushes crumbled cos it s a crappy titon lol and i havent got around to getting new ones - but thats the best way to cut a nice edge.
Dimple dies, you can use a vice for alloy, but these cheap presses are much easier for one man operation, plus the vice jaws mark the tops and im protective of my tools lol
started coating up the mesh in the bar in satin black last week when i was doing some other stuff, hopefully get that back on sometime in the near future, just too busy these days
Car spent the day getting a wheel alignment from Wholesale suspension in penrith - helpful guys and good setup for the low car
turns out the front caster rods are seized so couldnt be adjusted, so ill have to address this
cars driving great, would be better if my speedo would work and in turn power steering but still easy to drive.
next step is to swap with the spare caster rods and work on the adjustable ones - see if its worth putting new bushes in them or starting again.
and swap out the speed sender to see if that is causing the speedo problem - already rewired the ECU to fix up the japanese intrusions into the wiring and replaced the cluster with the nismo 300kph one so it shouldnt be them.
stock one is on the shelf now in lieu of the nismo 300kph one. speedo hasnt worked for a few years now lol
well it has actually, but only sometimes after a bit of a work out, and without fail at the track it works- so it makes it a bit harder to diagnose. really need some time on a hoist to trace wiring and swap out the sender unit
given me a thought though, might have to look at teh contacts on the back of the dash - as i believe it runs through the dash before it goes to the ecu .. hmmm
might as well try, forgot to remove the airbag light anyway haha
Its the sender lol - swapped it out with my daily's sender and work straight away.
heard a rumor that nissan dont sell them anymore ....
Good work on fixing it. I may have to check mine out.....lol when its actually running!
yeah dave, i had to go back in to get the hicas out
now i have to go in again for the airbag .. sigh lol
yeah michael, i was tempted to rip apart the sender unit and see whats inside that could cause the problem - but then it would have to stand still til i fixed or got another one - so i'll find a replacement then tinker :P
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
