  • Replies 390
Posted Images
ahhh john mate seen this beast come allong way...i member the day u droped the q45 in it...f**k it sounded good...good to see its all comin together well...ull have to take me for a spin once the blower and everything is on :) haha...cheers mate...top stuff!!
hahaha yeah for sure rob.
No updates for a while, sorta lost interest and drive for a little while as i had no idea when the computer was coming. But it left yesterday and should be here today. Hopefully fire it up for the first time tomorrow afternoon. Take it down the coast for a tune next week!! now im kinda of excited again.
Rob i got ur PM i will look into that, cheers.
UPDATE:
IT LIVES!! Fired it up last night, built up fuel pressure, turned it over and it idled like factory.. well it hunts a little with the blower and is a little rich... A test drive and some street tuning tonight.. Then a trip down the coast to be dyno'd.... It sounds unreal!!
Can forsee a few small problems with it... the rubber seals where the funny lookin manifold splits may leak.... Still have to put the engine damper on the calm it down... with the blower mounted so far to one side it ends up moving quite a bit, Fuel pump is farken noisy!! but i knew it would be.. mounted on the boot floor that now has no sound deadening..
All thats really left to do is pretty up the interior and do the cage... these are trivial though...
Well everything seemed to work out perfectly. It made 5psi from ~6k through to 7.2k where it just started to max the injectors out at 335hp@rears and stupid amounts of torque... car is very stupid to drive and overall im absolutely stoked... to take it any further id have to put bigger injectors and lower the compression, easy enough done... but it will do "for now"...
it makes progressive boost all the way to redline.
Going out to willowbank tonight for some shake down passes. Getting excited..
First time out on slicks should make things interesting..
ok well all worked out ok... kind of... couldnt manage under a 13 to start with but then we pulled the air cleaner off and played with some tyre pressures and the car dropped almost a second...
it managed a 12.42@112mph with a 1.7 60ft time
It wont change from first to second with out completely back off so it is loosing heaps of time there.. it kept going faster all night but andra kicked it off once it ran under 12.5 cause i didnt have front runners...
So i sourced some front runners yesterday wheels and tyres and they should be here by the end of the week...
Now i just have to sort the gearbox,, we may take it out for some more testing after power cruise before deciding which way we will head with the gearbox...
Options are speak to the guys in the states and send the valve body from the current gearbox over there to be modified, have a custom auto computer built for it and buy a big power handling rebuild kit for it.
And the other option is to make a Fully manualised C4 or turbo 400 bolt up... Either option is going to be really expensive... Im leaning more towards a built turbo 400 as parts seem to be cheaper for them and they are fairly cheap to get a ahold of second hand.
But this still means i will need to modifiy the drive shaft again and get another custom stall convertor built...
And at the moment i have zero cash... just waiting for the GTR to sell and then we'll see where we go from there....
More research is being done into a methanol enrichment system as well.... I want more power.. but first we have to get it down the strip with no headaches..
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
