Was at Gold Coast autosalon all weekend, was absolutely awesome!!
Took home Most Creative Conversion trophy and Most Powerful V8 trophy and autosalon magazine are going to do a feature on it :laugh: Cheering, bring on winternats!!
Edited by NA_R33
  • Replies 390
Posted Images
  • 3 weeks later...
no luck dude, gonna call a mate that works at nissan and investigate the possibility of a brand new crate engine. but that means big dollars... but i have a few major sponsors lined up so ill just have to take it as it comes.
infiniti usa sells them for about $4500 USD OUCH :ermm:
  • 4 weeks later...
Cheers dude, its in the back of the latest issue of zoom issue 100, but the proper feature will be in issue 103 so im told.
Yep , just got my copy of ZOOM issue 103 , and there it is . Good stuff .
awesome don, is it out in the new agents or are u a subscriber? i havent been able to find it..
update on the car, injectors arrived friday, 3 more bosch 044 pumps will be here end of the week, sticking the CF/fiberglass bonnet back on with Dzus Clips, methanol conversion and tune should be completed in the next few weeks along with a complete alloy dash, the it will be back to the strip to go for sick and get a whole heap of testing done before the nationals in september...
Also i hear a rumor that there may be a class for it at jamboree this year :no: neone else heard any more??
yep
bought it today - first time ive ever bought a zoom mag
good article too
car looks sexier in the 'flesh' ie bigger better pics
those Drift R rims make it look sexy
ps - going to wind the wick up on the 'charger soon? and NOS? could make a 10 sec pass nicely :(
  • 3 weeks later...
Just a quick update on the car guys, still running ~10-11 psi, 1600cc Methanol injectors magnaflow 750 pump, and a new tune we've turned out over 500hp at the treads... time to take it back to the strip and see how it go's....
Guys are you aware that Nizpro is running the VK56DE in their race boats? I have a short video of a web site that shows a VK56DE with twin turbos given a serious belting. Pretty sure you can purchase it from Nizpro.
If i could find someone to buy all my running gear (motor, gearbox, pfc, are ic, etc) I would get a VH45DE installed in my R33 aswell.
if its the same one i have seen it is of a VH45DE with twins strapped to the side of it..
I continually hear rumours of these super high power VH and VK engines floating about, but am still yet too find any hard evidence of them actually existing... Im basically learning everything from my own R n D, The only others i am aware of are all in the build process still and are not yet running. I may infact give nizpro a call today...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
