What's the story behind the car with the truck exhaust? :sick: It must be a joke...
its actually a pretty common thing in some groups in japan!!! alot of cars are styled just like that celica..............
Haha, I love the use of the term 'styled'. Like trailer parks sometimes get 'styled' by tornados :laugh:.
Wouldn't say it was pretty common though............ - exhaust is derived from the JDM trend 'Bosozoku style' and the flares are commonly combined with what the Japanese call 'low ride' and is known as 'Shakotan style'...
Edited by prince_skyline
i bought a trans temp guage hoping to have a look under the car tomorrow for a spot to install the prob in the sump or maybe in the outlet fluid line to the cooler.............
I'd be looking to braze/weld a bung into the sump. Best spot for it.:thumbsup: In the fluid line; you won't know what's going on when in manual mode (the GB isolates the cooler circuit) which is probably when you need it the most.
I've been idly wondering about the worth of welding a series of bungs into the trans sump (or a 1/2"plate tapped with BSP threads) one for temp gauge, one for a temp switch and a couple for a low pressure electric pump fed external cooler.
This would get around the issue of the gearbox bypassing the cooler then in manual tiptronic mode (when it's needed most). I know people reliably use small low pressure VDO pumps to scavenge and return oil to the sump in turbo setups where the drains are below sump level.
That said; it might be a bit more effort and expanse than is absolutely necessary...
An interesting thread for some detail; http://www.rbracing-rsr.com/oilsystems.htm
Edited by Daleo
exactly!!!! some people might think its a waste of time but i think its important seeing as i have it in manual mode 90% of the time and i dont want to destroy the fluid or the GB.
yeah might aswell get 4 bungs put in cant hurt really.
If you drive around in manual a lot why don't you try Aaron and Scotty's unlock mod? Its on here somewhere if you search, or I've got it bookmarked at home. Makes the cooler work all the time, even when it's in manual mode.
I'm looking at doing it when I get the shift kit and trans cooler in.
Doesn't that unlock the converter too?
I'd just like to be able to run the cooler when in manual mode with the converter locked. I'm pretty sure the unlock mod is pretty devastating for fuel economy too...
I'd heard that from Aaron, & it would want to be a great mod before I decided to go backwards on fuel economy. My ethos is always 'more for less', & I'm not sure that mod fits the job description.
yeah there's no way im doing wire cut mods........ and yeah the idea of the converter always being open and loosing power and fuel ecconomy its not worth it!!!!
Dale's idea with an external feed/pump to a cooler is probly the best way of doing it!!!
I don't think you lose power as such; because the converter is open, it'll actually build boost quicker because it flares a little.
The only issues I can see are the obvious necessity of a $250 pump & attendant lines, and a cooler; that's before you factor in modifying the sump with internal pick up and returns at opposite ends, to ensure you're cooling effectively, not just re-cooling the oil that just came out of the return.
Also, it's added complication when a decent sized cooler and a thermostat will probably do the job 90% of the time.
Tell me if I'm wrong, but surely driving in manual mode for a few minutes and then chucking it back in D would be fine? Let everything cool off and then have some fun again?
I fairly regularly drop it back into 2nd to drive through a roundabout and then chuck it back into D. *shrugs*
It depends on load I guess.....I know when my car was stock it was not a huge issue going across the gate all the time but I never stayed there more than a couple of minutes. But... with a little bit of HP/NM the standard GB cooks pretty quickly(better once the HD2 kit is done)........a couple of minutes wont hurt though imo......best idea is to knock it across the gate after the second gear shift.......with the standard turbo revving the thing to 6,500rpm is a waist anyway + your already doing over 110km's.
Mind you Paul you will find after you do a couple of the VB's a difference in oil colour between those who drive across the gate all the time and those that don't.
Edited by Jetwreck
I was thinking of drawing up a simple mod to allow the ATF to pump thru the cooler whilst in manual mode, BUT switch back to standard when in D, thus not buggering my exceptional fuel economy. I'll work on this soon, maybe this weekend, & post some results if anyone is interested.
Craig, I wouldn't have though there'd be that much difference in fluid colour (I'm guessing some looked a bit 'burnt'?) so I will be using manual mode sparingly until I sort something.
im interested. Would this be a wiring mod or require any additional parts beyond a switch/wires??
Maybe a relay so it happens automatically, but it shouldn't cost more than pocket change. I haven't had more than a cursory glance, but noticed a few things when reading up on speed wires for the cruise control.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
