im interested. Would this be a wiring mod or require any additional parts beyond a switch/wires??
With the shift kit in, there is less slippage therefore less heat created
haha im only interested in doing the job properly not cutting wires *Cough* i mean corners *cough* :P
Seems anything mechanical in our cars runs on wires somewhere. IMO you can't progress unless your prepared to cut a few here & there :D .
why not??
i kinda did that when i was doing the 'wire cut' mod. cut the wrong wire hahah
And how did that work out for you? Ended up with a 5 cylinder Lolvo from memory.:teehee:
mine pops too when the exhaust is hot. mostly in manual mode when it stays in gear when i back off the throttle
Nice! It must be that awesome ECU throwing heaps of fuel into your engine.
still running plumback so i'll check the hoses and vacuum but i need to replace the BOV so hopefully get that before x'mas.
my thoughts were along the lines of running rich and BOV playing up............
its really tempting to take the cat out HAHA and watch all the flamage!!!!! it'll remind me of my other flaming wagon :D
  • 4 weeks later...
fitted a new BOV today, i got the turbosmart nissan dual port............... even set on the softest setting im now peaking at 19PSI,
first of all is that right? second what do i need to be doing to stay safe............ ive been running 95Ron but im thinking i should be running 98Ron now just to be sure its all good and safe.
i know people were running there stock turbo's at 20PSI but i just want to know what effecs this is going to have on my engine and on the turbo................(yes i know the turbo is going to have a shorter life span!!!!)
cheers, Theo.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
