i got the instruction manual for the wideband i want to make sure it's going to be useful before i get it.
"The Bar Graph Display (BGD) Range Setting Mode allows you to fine tune the resolution of this instrument for your specific application. With upper and lower set point adjustability, you can set the BGD to utilize the exact range that the engine / vehicle operates within and see exactly how rich or lean you are running in relation to your current set up and tune. Adjusting your BGD limits also adjusts the scaling of the 0-4v data logger output supplied from the gauge. The selected low set point of the BGD Range becomes the 0v value of the data logger output. The selected high set point of the BGD Range becomes the 4v value of the data logger output. Whenever you change these points, the instrument adjusts the data logger output so that the 0-4v signal is always linear between your chosen set points. "
Looks pretty good Theo. WOT input looks interesting, mine doesn't have that. Although the Innovate's have a built in data logger, whereas the Auto Meter seems to want one connected (which is probably the output you'd use for the F-con).
But at the end of the day it depends on whether the tuner wants to use it constantly, or whether you just use one of those ones you can stick in the tailpipe for the day.
My dyno has its own wideband that logs afr to the graph.
I have 2 standalone widebands that can be used for datalogging or roadtuning.
I recommend putting the wideband in for piece of mind, can then see if u have a lean out etc due to fuel surge or fuel pump failures etc
Howd it go today Theo :)
So all ur worry was a false alarm, the 02 sensor reading in the cypher software the Alex was reading from has no bearing on what the actual AFR's are. Tune was fine except for the 1 area which u heard a ping at low rpm high load which was very difficult to replicate on the dyno due to the auto but i found it and fixed it.
Ps, nice single pegger skid when u left :P
Very interesting today Jez- so we know stock ECU > Theos aftermarket computer> motor.
And I can only read what the stockie puts out.
Had a great run coming back down the old Pac- volvo convoy.
Nice :)
Yeah was very weird, especially how much difference there was in the ignition timing output from his aftermarket ecu to ur software
So second tune and no gains? C'mon Theo, slap a Hypergear in there... :P
All the stock ecu does now Alex is run the throttle and cams, nothing else has a bearing other than to keep the MIL away. I have no idea what signals the Fcon sends back to keep it happy but whatever it is, thank you mr HKS.
Jez also found some little parts of the pre-loaded tune that were no so good - and sorted them out.
I've got some logs from the power runs. Might load them if I can be stuffed
That's why I wouldn't use maps designed for other cars, you will always end up chasing gremlins in the tune imo.
Post them up Alex, I would be interested to learn what the Fcon is doing to the stock ecu and that may hold the key. If I end up going down the Link G4 route I may need the same signal bending output maps... The manual transmission will open up a world of possibilities. ;)
Honestly i wouldnt trust the log files as even the timing etc is way off
Exactly right.
As I said it goes Stock ECU > aftermarket>engine.
So Ign timing is not correct for the engine, but other things like Cams, AFM, and BFS are all able to be seen accurately.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
