Jay - stock item is a viscous LSD. Aftermarket ones (CUSCO, NISMO, KaaZ, etc) are also LSDs, but they are mechanical and utilise clutch plates. I don't think anyone seriously wants to drive around with a fully locked diff... :P
I think 2-way LSDs will provide the most consistent reaction when the tail steps out of line as the locking action remains the same off or on throttle. 1.5-way can be a bit more snappy, as the locking action when off-throttle is half of what it was on-throttle. I run a 2-way LSD in my car for circuit / drift use. It was quieter when I had a heavy duty clutch, but bites a lot harder now and is noiser with my button clutch. Usually get confused onlookers wondering what is wrong with my car when the LSD does it thing @ parking speeds, but that's all.
  • Replies 42
Duncan, you ask why anyone would want anything but a 1 way - well I definately prefer a 1.5 or 2way. With a 1 way, if you get oversteer and back off, your back end can whip around really hard, throwing the rear in the opposite direction. A 2 way will not do this, and a 1.5 wont either.
2 way (according to sydneykid) has an advantage if trail braking into corners. I dont do this often, but if you do get a corner come up unexpectedly (it has happened to me) and you are hard on the brakes into the corner, the weight can lift off the inside rear tyre resulting in sudden hard oversteer (the rear wheels are not working together, power goes to the wheel with the least resistance) - which can be pretty hard to catch. So there is a benefit in that it keeps power to both wheels.
Stock nissan skyline diff is a LSD, which stands for limited slip diff. There are many types of LSD, the stock one is viscous - it has oil in it. This will allow one wheel to spin before the diff locks, when both wheels will spin. Viscous diffs can be a little unpredictable, esp when they get older. Open wheeling, then if the wheels lock sometimes kicking the back end out unpredictably and wider/quicker than a mechanical LSD.
Mechanical LSD uses plates like clutches. when the plates are pushed together, the rears lock. 1 way will lock only under accelleration, not under decelleration. 1.5 will lock under accelleration, but only 50% (or there abouts) of the locking pressure on decelleration. 2 way locks fully on accelleration and decelleration. (this isnt 100% accurate, but you get the idea).
a mechanical diff makes a huge difference to how the car handles, I would rate it nearly as much difference as fitting decent coilovers (on my R33, with 63,000kms on it). It puts power down better (car is quicker, esp off the line), the predictability is perfectly consistant. The rear doesnt step anywhere near as wide as with the stock diff in a straight line. In corners, you can feel the rear coming around, not just jumping wide (as with the stock unit) when traction starts to brake. I find the car seems to sit flatter in corners too.
If the rear does get too wide (with 1.5 and esp 2 way) taking your foot off the accellerator will result in it coming back in a very controller manner, not snapping around in the opposite direction. This is of couse unless you have left it too long, beyond the point of no return.
To give you an idea of the improvement in traction, previously in a straight line, I couldnt even drive the car off the line without chirping, and first and second were useles - not traction, wild sideways and just dangerous on the street if I tried to give the car too much - Just recently, I lined up another member off this forum, him with RE540s, me with crappy revspecs, but I was actually pulling ahead of him slightly (he is running 12s), we were both spinning the rears, but I wasnt just sitting there making noise and swaying across the lanes.
2 way a disadvantage? depends on what you are after. much better for drift, and a little more predictable if you are coming off the power during oversteer (esp heavy oversteer) - but a little more understeer. Well, I can also add, that after fitting the 2 way, I fitted adjustable castor rods, where previously I had castor bushes (that gave me 7 1/2 deg castor). The rods are adjusted about 1 cm shorter from the bushes, and turn in is just amazing - the car handles like it is much smaller. (and besides, as $350 for a 2 way, there is no way I was going to pass it up:p)
A mechanical diff can be a bit clunky, and chirp the inner wheel when turning in a tight circle - another downside is the back end gets out alot quicker in the wet than with a viscous diff, but once again it is predictable, and if you drive suitably, not unstreetable at all (unlike an old GT falcon I owned, couldnt corner in the wet, esp if braking into traffic, bloody thing used to do 360s all the time)
Anybody who is thinking of doing this - do it NOW. Not only is it a great handling mod, you get the power down much better, and the car is alot quicker to drive, straight line and corners. I actually thought I had a 4.3:1 ratio (vice R33 4.1:1) at first, the difference is that much.
As mentioned there are different types of LSD, mechanical and viscous are but two.
"2 way (according to sydneykid) has an advantage if trail braking into corners. I dont do this often, but if you do get a corner come up unexpectedly (it has happened to me) and you are hard on the brakes into the corner, the weight can lift off the inside rear tyre resulting in sudden hard oversteer (the rear wheels are not working together, power goes to the wheel with the least resistance) - which can be pretty hard to catch. So there is a benefit in that it keeps power to both wheels."
Yeah, I should clarify that I'm talking purely for track handling, where corners shouldn't come up unexpectedly :starwars:. As for trail braking, I regularly use that into long corners, even better when you left foot brake as well.
Of course, the main reason to trail brake is to stop understeer (dont allow the weight to shift back to the rear, keep it on the front, maximise traction), so yes, it does cause the rear to go light....and if you have calculated wrong you end up spinning in the corner (been there done that). And...thats exactly why I can't see the benefit of a 2 way diff, assuming it encourages understeer thats - why you were trail braking in the first place. Hope that made sense.
I'm happy to accept that 2 way may help for dorifto, I don't know anything about it....but I can't see a benefit for a circuit car?
Great thread here, anyone else using a mech diff?
So whats the difference between a LSD and a locker? Not locker as in a spool or welded being locked 100% of the time but as in a detroit style locker? The previous owner said it had a detroit style locker diff. Its not locked full time as doing a full lock u turn there is no wheel skip at all. How do I tell if its a locker style or just a normal mech LSD? One thing that does happen is sometimes on take off, whether driving normal or trying to launch is that the rear wheels will " chatter ". Like when a wheel skips but its both of them and I am trying to drive straight. Someone told me its the diff locking/unlocking repeatably. I am not so sure though. As I have 265 rubber and I reckon its just struggling to spin up. Anybody know the workings of a detroit locker?
  • 1 month later...
In my series of cars, its something i make sure of, when the clutch is dumped, both wheels are spinning.... nothing sh1ts me more than a vn v6 or something like that, with one stocky on the right rear doing a donut with the circumference the same as a trucks turning circle.
i had borg warner LSDs in my first 2 cars, they were great but over time with harsh treatment they started single wheeling more and more often... then i got a minispool, a lot of people were against that saying they were unpredictable etc etc... I thought it was great, it wasnt overly harsh when cornering at low speeds (city driving) and currently i have a Cusco locker.
The locker is VERY harsh and its so weird how something that sounds so harsh and bad is so good. I find having the locker the car is much more predictable when the rear wheels are losing traction, mechanical 2 way diffs seem a LOT similar to me, but the locker is definitely more harsh when cornering at low speed.
The bad thing is, it is a DEFINITE tyre f**ker. So if you have large wheels on the back, tires with even normal driving dont last long = Remoulds are a great thing =)
B-man, I got mine from Powerplay imports in sydney. The guy thought it was a 1 way, and was quite keen to unload it. First thing he said was 'I dont want much for it'.
I got lucky, he offered it for $350 fitted, I asked him if he could send it here for that price - he seemed glad to be rid of it.
When I unpacked it, and checked it against a couple of parts catalogues - found it was a Nismo 2 Way.
I agree with Dean, check wreckers and car dealers. Most dealers wont put a car on the lot with a 2 way diff - frightens the punters off:)
Been speaking to a few fellas bout this
The Dorifto folks swear by the 2 way
For Track - 1 or 1.5 prolly 1.5
So I think I'll go for a 1.5. If anyone sees one going let me know as I'm on the hunt now.
I priced the 1.5 way Cusco locker and it was like $1500 from Greenline and that's not delivered. Ouch !
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
