Garrett have sold out of GTX stock worldwide, there is certainly a lot of interest. There must be plenty of builds in the pipework.
It looks like you have your answer, GT3071 will be the obvious choice. :thumbsup:
  • Replies 119
Posted Images
I have/had the GT3076 0.82 IW, I found it a little bit laggy for my liking, but I still enjoyed it, I was pulling ~265rwkw at 15psi
You also have to remember, everyone's case/experience with these turbos is going to be different because of different set ups. So what may work well for someone else doesn't mean you are going to get the same results.
I would maybe suggest the GTX3071 or strongly suggest the GT3076. Maybe speak to Morrie at Horsepower in A Box, he has played around a little bit with the new GTX series - GTX3076 only I think, can't remember.
Sounds like you have 3 choices in 0.82 IW:
- 3071
- 3076 52 Trim (Disco's choice)
- 3076 56 Trim
The earlier on the list the more responsive and the less top end. The later the less responsive and the more top end. Although we are not talking huge differences between all of them, maybe 3-400rpm in response and say 20-30rwkw in top end.
Joeyjoejoeshabadoo (sp) seems to be the ideal Case for 3071 (admitantly 2835 .67 or something). Making 260ish at 1 bar. Full boost about 3300. Sounds perect in theory
it is ;)
dan (halle) has just changed from a 2835 to a 3037, so he should have his old kit for sale...
- 3071
- 3076 56 Trim
FWIW I've tried both the 3071 and 3076 52 trim with twin scroll .78 rear housing on my SR20.
With a 3.5 inch dump/exhaust (up from 3 inch) I managed to get the 3076 52 trim making more mid range than the 3071. To make it clear, the 3076 52 trim was more livelier than the 3071 at any rpm.
The 3076 52 trim is a great "no compromise" turbo compared to the 3071 for 290+ rwks'. At this level of power, traction is an issue and is probably no use making more for a rwd street car. BUT if you want more.....just add E85!!
The only downside (if you call it a downside) is that the 3076 makes alot more spool noise than the 3071 due to the surge slots in the 3076 compressor housing.
Edited by juggernaut1
i wish you had done that back to back without changing the exhaust man :/
Don't think things would have improved, and possibly worsened/caused damage as the 3071 was already surging when coming onto boost wih the 3 inch exhaust.
A better flowing exhaust would have possibly made it surge more when coming onto boost. The surging tells me I couldn't put any more boost into it when coming onto boost so I doubt it could make any more power in the mid range.
The surge slotted 3076 52 trim allowed me to at least match the 3071 to build boost and make significantly more mid range in the process - probably because A - it was not surging and B - it was possibly a cooler/denser intake charge with the slightly larger compressor and C - with the larger dump there was a bigger pressure differential across the turbine when coming onto boost which pulled the 3076 onto boost earlier than expected.
I.e on the dyno the 3076 52 trim was making positive pressure by around 2300rpm, 1 bar at around 3350rpm and 1.5 bar (22 psi) by 3750 rpm on a sr20.
I had a similar experience, Mine was a little laggy but made 300 odd RWKW at 18psi so it was pretty good. But in changing to a RB26 with twin HKS2510s I realised how much better 300 rwkw could feel!
Did you have the 56 Trim 3076?
What ever trim is the same as what HKS uses for the RB25 3037....so from my fuzzy memory I think that is the 56T. I have pics of the ID tag somewhere. If i remember i will go look it up!
cheers guys. all info is massively helpful. something like the 3037 was what i was after but the $$ isnt there for a genuine kit. im now leaning towards to 3076 with 52t, but any more helpful info is appreciated
not quite, i rang MTQ and they have in stock, a touch over 2k though
that sounds pretty much perfect, with a reasonable top end to boot.. this seems the best compramise between spool and top end.
while your on the dump pipe topic. ive read a split dump set up on the garret IW set ups arent ideal and a 'bellmouth' set up works better? the rest of my exhaust is a 4" magic cat and 4" cat back so that back pressure should be ok
thanks again
Yeh, I would never buy from here for that reason. For much the same price I got the GTX 3071, Tial 0.82 stainless Vband housing and a 45mm turbosmart wastegate delivered, I just have to wait for stock... :dry:
So in the end much of a muchness and either should do the job? Been doing some research this arvo. Plenty of info on the 76 with 56 trim on RB not alot with the 52. so if it's comparable to the 3037 (even with the rear housing difference) then there's also alot
thanks again
I've had the CES split dump pipe on the stock s15 turbo. Never had it on a dyno but it was a fantastic upgrade from a seat of the pants feel.
However, depending on the quality of the split dump and how soon after the slit dump merges back into the main exhaust can give varying results (good and bad). My current setup has the external gates merging back in just before the cat i.e. merge it back in as late as possible. On IW setups there have been mixed results as I previously mentioned. I think the concensus is to go a quality bell mouth setup.
I'm no expert, but this ^ is kinda what i've gleaned from this thread.
I have a 3071 56T .82 and love it. Not having had a 3076 or any other Garrett turbo i suppose it's easy to say that, however i don't think the differences in trim and comp wheel size are really worth fussing over *too* much.
(This all assumes that the rest of your setup is sorted)
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
