  • Replies 155
J31 maxima rear drums are a slight upgrade if you wanna clear 15's, thats if the j31 calipers bolt on( haven't got round to confirming /sourcing the brakes) and will need to redrill to 4 stud as they are 5
  • 2 months later...
The buckles should be sweet.
R32/R33 front seats can be swapped in and their original buckles used, so I can't imagine the rears are different.
The actual assembly/box thing that retracts the belts might be a different shape/fit though.
so i know its in the parts thread. but not exactly what im after.
my rack is leakin in the laurel..
it was originally hicas. ive since put in a non hicas cradle and removed the lines yadda yadda.
i plan to replace the rack when i remove the engine and would like to put a non hicas rack in if possible.
can i use a non hicas s13 rack or will the lines not fit up??
I've grabbed pics of the non hicas A31 and S13 ps racks iff you guys wanted to give them a look. There's 2 of each, Ceffy are the top ones.
S13
Looks like if you have the top Cef rack either S13 rack should line up pretty easily, the other ceff rack(duet-ss?) is completely different.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
