Hey mat, where did all the dirt come from to block the injectors? thats pretty suprising, are those billet fuel filters any good, thought it would of prevented the injectors from getting blocked up, could of been a rebuild job? :spank:
when i was watching my tuner install the pump, he mentioned that my tank was very clean inside, and that some cars that have been in floods in japan will have alot of shit in the tank, just wondering if your your tank is clean or will the dirt build up again.. :whistling:
what brand are your 275? what gear was traction breaking? :dry: im still tossing up over ku36, r1r's or RSR's
Edited by SliverS2
Gumtree tour car is epic I lie if!!!!!!!
Ahh can't wait for natro a
15tg nov ever yewwww
Getting your drunk whoring on were you? :P I sent it to a translator :laugh:
From where we dont know.... Everything in the fuel system was apart so it could have been anything.... Without knowing where or how we are being extra cautious hence the double filters etc
Ive seen in my tank as ive been working in there a few times and it all looks pretty good to me.... Have run my hand in the tank and it seems fine! It'll be a temporary issue that we will resolve :yes:
As for the tyres, they are a joke lol..... They have one purpose and that is skids at powerplay! I thought being that wide that they would get some grip but nope :laugh: should have listened to Martin haha
Will be going RSR's all round in a couple of weeks, best cheap option around at the moment!
Martin (m.j.h) worked his magic with my paint and removed a heap of marks.... I know the paint is shot but it still come up nice and shiny for a nugget
oh yes, i want those brakes.. :yes:
are they physically bigger than stock or just alot better..?
Same size just a much better design.... Seen to work brilliant when u really stand on them... Fronts are next but still trying to work out a plan... Will just throw a fresh set of pads in for now...
Yeh after reading the reviews on here, it sounds like the quality has gone right up. K-Sport and D2 are both very good apparently. I was going to go Wilwood if Phil ever organised another group buy, but doesn't look like he is.
Yeah well for now i dont have time to discuss with an engineer in terms of legality etc so ill just upgrade to DBA4000 and A1RM for now to match the rear, with that and the braided lines and master cylinder stopper it should pull up pretty well!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
