Oh and as some may have noticed, the bonnet is freshly painted but does not yet have the lip back on as i havent had the time.......
I replaced the front pads and rotors and flushed the brake fluid prior to SAU Nats but ran out of time to do the braided lines and paint the callipers so ill tackle that later -
I was still undecided about the big brake kit so i upgraded the fronts and DAMN they work well when hot! They are A1RM pads with the DBA4000 rotors
While i was in Sydney i got Federal RSR's all round fitted and balanced, the guys at Tyres For Less were super helpful but i noticed a knock into there driveway and it turns out i had broken a traction rod with 1 too many skids, they are a crap design (D-Project or Project-D cant remember) they rely on 4 welds..... So i limped over too Just Jap and grabbed another arm to keep me going......
Once the tyres and arm were all sorted i got Wheel Align specs from Adz which were simple AWESOME, car has never handled so well, it tracks dead straight and is like its on rails
Oh and while i am on the topic is suspension arms, my ISC arms were stuffed and seized, i got them second hand and they were garbage so i fit a new offset V2 style castor arm from GKTECH
So, while all this was going on i decided to become and old fart..... My car featured on one of my 2 cakes (Yes i am a fat kent i know)
It was a HUGE surprise party which was just awesome, due to lowering the car i couldnt get a normal jack under it so too my surprise my amazing friends and family got me a prezzy which i love
Somehow i randomly found gear oil in my chassis rail LOL, i have NFI how or why its in there but i just degreased the hell out of it and no prob since, was really odd!
So i figured i was prepped for nats, loaded with E85, brakes and tyres good to go and was super keen
But the car REALLY didnt want to go..... Had HKS errors and E sensor errors on the way to pick up Carmen from the airport, it was the start of a long day....
Does it go?
Yeah i drove it to JEM after the event and they said i am not having it back until i do what i was told in the first place and do the fuel system properly, i shouldnt have been a tight ass and i wouldnt have had these dramas lol :P
Good girl.
Most used tool in your shed I'm sure.
For those that didnt see it, i couldnt get more than half a lap with any sort of power so i was just obnoxious on the outlap for lolz :P
Good girl.
Yeah itll get a workout! I love it! Snap On/Blue Point quality is always top notch!
I got other prezzies like Snap On tool bag and lots of booze but the Jack seemed relevant to a build thread :D
Next one is at 1:30, gotta pass the time somehow! :P
Grats on the trophy!
Good luck mate! Sounds like your all over it!
Haha thanks! I laughed when Ash called my name!
so how good are the RSR's? do they hold any sort of traction?
They are good mate, gotta get them hot but 3rd grips up nicely...... The video shows them dead cold so of course it was just skids.......
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
