Ooooo 26/30 with twin hta3076r's?!?!?!
If it doubt... Moar power!!!
But no, i will pull the engine out and check the bottom end though! The car will be off the scene for around 8 weeks at this stage :)
End up working out what that idle problem was?
Not yet... Ill put a smoke tester on it as if i start it now it will just rev high and on a dead cold engine that cant be good! Could be an intake gasket or something but the engine will probably come out so i can clean some stuff up anyway so ill sort it out :) If anything it probably helped me on the day!
Better driver?? Hahaha awesome effort means I need to get semis to beat you now lol
Haha nah just a refined driver :P
Get Semis so we can go have fun! Ill get the RWD going as quick as i can ;)
Two of the Big Bottles? :woot:
So bummed I couldn't get off work for this. (I actually thought it was on the weekend) :/
Would've been mad.
Haha and Harry i need them by tonight!!!
Here we see the GeeTeeTee hunting it's prey in the wild, waiting for the opportune moment to GAAAAAAAAATE :P
Doesn't exactly sneak up on people though, they generally hear it coming :P
So basically it has been a bloody busy few weeks! Unfortunately not enough time for the car BUT hopefully i will be doing plenty to it over the coming months...
One of the things we managed to do over the past few weeks was get our drawer setup sorted, this will make future track days SO much easier... The drawers behind the fridge will become tool boxes that can lift out with the flick of a latch and have handles on both sides so we can take them to the pits if needed... The overall quality is mint!
  • Like 3
So we took the 4WD up to the Barringtons for a play in the snow and i saw this -
And i thought to myself...... I need to get the fkn car going again so i can abide by this road rule!!!!!!!!!!!
  • Like 1
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
