Hey everyone,
So I'm putting my 32 GTS-t through regency to get the defect cleared. I think I've got everything covered, the car is pretty much bog stock standard but I thought I might enlist the help of fellow skyline owners with suggestoins of things to check. On the defect notice, the (wank face) motor bike copper wrote "pod filter not fixed into place, exhaust and bald tires" and then said to me "they'll check over anything at regency anyway"... I knew that, in fact this is the second time I've been defected. So....
Here is a list of everything I've checked and/or changed back to stock (note: I bought the car absolutely stock so I would have all the stock parts if I got defected):
Suspension standard
brand new tyres on stock rims
standard exhaust all the way through
strut braces taken off
standard air box refittted
fresh service (spark plugs, oil, fluids, etc)
spoiler back on
steering rack boots split, changed them both
pressure cleaned underside and engine bay, used degreaser (cleanest it's been in years)
boost guage, turbo timer, bleed valve removed
Upholstery cleaned, no loose bits or wiring (one problem, the back right seat belt doesnt retract so I stuffed the excess belt behind the seat. does anyone think they'll check?)new brake discs and pads all round, fixed a leaky brake pipe at caliper
fixed leaking fuel hoses above tank
noisy thrust bearing because it has an extreme heavy duty clutch and pressure plate
removed window tint (had to do that last time i went thorugh regency)
(I put things in bold I'm not sure if I should be concerned about)
That's all I can think of right now. If anyone has any suggestions or any SA owners wanna come see or give their opininons too that would be greatly appreciated. Also with transport SA (Service SA) they only do one way trips now apparantly, so even if I do get it cleared how do I get it home??? I don't wanna tow it. Anyone wanna lend me their trader plates for the trip? :worship: I've been out of 'the game' for ages and would love to make new friends, with skylines again.
Anyway, any help would be greatly appreciated or if you just wanna wish me look that'd be cool too. The 32 goes in on Tue 29th (next week)
WISH ME LUCK!
https://www.sau.com.au/forums/topic/358547-putting-my-car-through-regency/
They check the seat belts if they don't retract properly, I got done for that, Just unbolt the seat belt in the boot (should only be one bolt) and just squirt a bit of sewing oil into the mechanism DON'T pull it apart tho. then just bolt it back in and pull and retract it until it retracts by itself. That worked for me. My thrust bearing is pretty noisy too and they didn't say anything about it. and the guy i had had was a wanker and even defected me for not having all the steering column surround so the thrust bearing wasn't an issue
yeah the first time i went through they 'shook' the wheels pretty thouroughly and the end result was I had to change my right castor rod and left upper control arm. Had a visual inspection at Graham West the other day and they said the bushes on the right castor rod were starting to crack but should still get through regency and should be taken care of but not urgent.
Thanks heaps for your responses so far, guys!
30% on fronts, 35% on backs. and i was apparantly 1% over on the fronts (but he checked it twice because i was actually 2% under with the first device he used). when i've seen cars with darker 'legal' tint...
They changed the tinting rules back in January 2010 - it used to be like 70% front/rear, but they since changed it - it's now 35% front, rear, etc:
http://www.transport.sa.gov.au/pdfs/personal_transport/light_vehicles_pdfs/MR430_Window_Tinting.pdf
There are also special provisions for cars with factory privacy glass - in the case of factory privacy glass (like many of our skylines) its legal as long as it has an 'AS2' or 'AS3' marking ('AS1' is clear).
This reminds me i had to laugh when i took my car to get it reregistered in SA.
The guy from Regency spent about 10 mins trying to get the tint off of my windows, i have privacy glass. :nyaanyaa:
Made me chuckle lots and then he gave me a warning about it but still let me through.
ok sweet! sewing oil then, i thought of maybe rp7 or something but i'll give that a go. Do I just buy that form mitre 10? (don't do a lot of sewing... :cool: )
Just go to woolies or coles they should have it. I just used my mates mums lol
alright the seat belt is fixed. the only i have left is the rear strut brace. This is because when I got Graham West to replace my factory suspension They did up one of the bolts so tight I've snapped a ratchet and spanner (both cheap) trying to undo it. When I attacked it with my Snap-On thruster it began to round off the nut (hexagon style). Now i keep hearing they ARE legal even though I thought they weren't. Anyone been through regency with them? I'm thinking I might just leave it there...
From memory the strut braces are not illegal, so you should be fine. Mate sounds like that car is all good for regency. I have taken my ride through and constantly crossing fingers :P so you should not have a problem :D
Good Luck
Good Luck
Thanks mate! I'm sure I'll need all the luck I can get. And thanks everyone else for your help and everything :D
Alright guys so I JUST got home from regency park...................I got through!!! First go and everything! To be honest, I was meticulous about making sure the car was up to standard and above all clean. I didn't even get one of the young guys that apparantly are way more leniant, I had an older dude who was fair all-round. My right castor rod bushe is starting to crack but have no give (yet) so need to get them changed. If anyone wants help and/or tips through the process I'm all ears and definitely up for helping out other skyline owners.
What he checked and when:
1) Drove the car over the pit which has a concrete slab to 'hit' anything that's too low. I think the legal requirement is 110mm for any part of the undercarriage.
2) With car on, he got me to 'rock' the steering wheel slightly left and right continuosly while he checked steering rack and front suspension (in the pit)
3) All indicators and lights individually checked (parkers, low-beam, hi-beam, brakes, etc).
4) Spray winscreen washers- this is to check that the spray jets and also that the wipers clear the water properly (I bought new blades before going just in case)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
