  • Replies 804
Heh, mine was more than that... Damn HKS products =/
660 to diagnose lol. Power figure is good though.
Yeah right that's the final step for me too. EVC 5? Haha
Lol yeah basically the diaphram in the actuator has split so that was f**ked and they had to install a new Garrett item to get the boost under control. Some clown had rewired the loom for my Porfec B with speaker wire and gaffa tape...hooligans...but when they rewired it properly they found the board iside the ebc was dead.
Have to say, its a world better than before...turbo would spool from idle and make 34 psi by 5700rpm then RnR and was just crap. Only thing I need now is an EVC and then I wont lose torque up top and torque curve will be straight up and then dead flat, fingers crossed aha
What does the GTR make bro?
Edited by EXEMPT
Ok lads so I'm thinking about cruise dates and options....
Option 1
17th April (Sunday)
Meeting time: 11am
Meeting spot: Perth Esplanade Carpark
Destination: East - Serpentine Dam - passing through all those delicious Gooseberry Hill roads etc
Activity: Defs a photo shoot of all the 32s and any other car's that attend, maybe suss a BBQ or something?
Option 2
24th April (Sunday)
Meeting time: 11am
Meeting Spot: Perth Esplanade Carpark
Destination: Yanchep (apparently you don't need to use Wanneroo Rd to get there anymore and Marmion Ave goes there now???)
Activity: Photo shoot and BBQ or something
Any suggestions of other options or changes are more than welcome. I'll admit never done a cruise before...
I'm up for either dates/destinations. :) Doesn't bother me.
We had the R32 GT-R 21st Anniversary last year in NSW, and this was just a handful of the R32's that turned up.
Awesome fun.
Awesome fun.
Sweet bro! We'll see what the others have to say and go from there ay.
Hey guys, here a pic of my bunky Shiter, currently in the middle of a Full panelbeat and respray in the same colour, but with genuine GTR bumper, Bonnet, and Grill :)
Possibly keen to join fellow R32 owners on a day cruise aswell, though normaly dont venture out in daytime hours :P
Did you get a new reo as well with the GTR bar? And do you still have your old front bar + lip + bonnet?
Your car is gonna look sick with the GTR parts and respray. :)
Hey man, gtr bar and grill havent arrived yet, coming in on a half cut in the next week or soo, but geting the reo aswell.
Yeah still have the bumper bonnet and lip, (whys that?)
i cant wait to get her back will be a huge improvment, also have the genuine sideskirts and rear pods, not sure if im fitting them yet or not though.
Also love your car dude, found it on google ages ago when searching for ideas for mine, and then saw you post it on antilag, keen to see in person :)
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
