Who does the work though.
Less a Haltech PS2000 and the install and tune + markup! = $16,000 left. Then shipping/duty $14,000 left. Then workshop fee's for motor removal and install = $13,000 left. Then exhaust = $12,000 left. Fuel System = $10,000 left. Misc = $9,000 left
You now have $9,000 left to get to 800hp reliably!....how much are the 3.8lt or 4.2lt conversions? and then how much is turbo kit from the workshop going to charge?
Like I said 20K with you doing most of the work is good for at least 800HP.....a workshop doing most of the work at least 600HP....and I am talking with reliability.
1. Never said that the workshop would be doing all the work - that'd be the money burner
2. No chance I'd pay $4k for the Haltech (ViPec installed and tuned for $2k down here)
3. Stroker kits can be had for under $5k depending on what you want or 700hp rated built VQ35 for $10k (plus shipping - yes I know you have to supply a VQ35).
4. All I am saying is for $20k, you could get around 600-700hp* from a VQ35 no problem... reliably
* actually I said big power... but I'd say that 600-700hp from a 3.5L V6 is big power... well it is to me anyway :whistling:
  • Replies 70
Posted Images
horses for on courses on ECU's...personal preference i guess!
Going around in circles on this 20K one!!!!
  • 1 month later...
BUMP
Ok...
I've been reading through this thread with interest as I've spoken to a few tuners over here in W.A and very few have had experience with the VQ25det engines. I had one guy who said a lot of the cost would be on r&d so if I can find out specifics then he can cost it up for me.......... I've been looking to do this for a while now but its probably just getting to the point where there is enough info available....
I'm getting everything done at one time and then thats it, set and forget.
I'm not very mechanically minded so bear with me
Budget 8-10k
Wanted power 270awkw and 800nm
Things I know I need:
Hi flow turbo ( What core is best - I want early spool if possible)
Full custom TBE
Emanage ultimate ( Was told by 2 people it's not a good unit )
EBC (Best type?)
HDI Intercooler
Fuel Pump
Injectors ( Which ones )
Anything else I've missed?
Any other mods I can get them to do at the same time for more power earlier (something mentioned earler in the thread - A mod by Scotty but I didn't quite understand )
Throttle restriction removal ( Cut cable ?)
Edited by ArdentEagle
He's probably trying to sell his car again. :P
nah....just cannot be bothered type up the +'s and m -'s of each turbo......oh and what you have to do to get em working properly.
e.g. Don't waste your time going for my turbo if you don't have some way of sorting out the low end restriction/s.
why not? I thought it would be the better option as you can spool on stall.
bush bearing wont in the same size..
nup....still will be a POS!.....the standard ECU on my car is soooooooooooooooooooo much different to the Awesome.....sorry Nismo!
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
