Ya she is in too....wouldn it be eaisier to count cars instead of ppl.....so have a shoe polish and number cars like DECA...so its easier..who ever rocks up to the initial meet gets a number...and who ever doesnt, dont and miss out....this makes sure all the diff clubs socialise with eachother and numbers like that looks kewl on the car :D
But that would require me to wash my car! I was hoping to get away without washing my car till next Deca.
  • Replies 337
Posted Images
Cool, and yeh nearby shopping centre car park seems like the go. I just left a message with Village to call me asap tomorrow because I need to see how many spots there are for one movie... we may end up taking up a whole cinema....
Hey Adam - did you find out how many spots for one movie?
It would be unreal if the whole cinema was full of imports...
Just an idea, why dont you post a link to the flyer in this thread and everyone can print their own? Saves you having to print all of them yourself and no issue of not having printed enough.
Dont worry - 360 spots in the biggest cinema... that when 2 cars tuck in between 2 polls.
because it is then a bit too easy for people to copy an extra one for their friends and a close estimate to the real number is essential as village reserve a certain amount of tickets for us so some actual members may then miss out ..etc...
Anyone going to the GTCC club movie night the next night? I was going to do both but unless the movie is biblically awesome (which, let's face it, isn't likely), I won't go to GTCC
Are we counting cars or people? Because if it's cars then its 2 for me, but if it's people it could be 4
+1 i may be bringin 2 mates in my car
I'd prefer not to go to the gtcc meet for the movie as they are meeting at Knox on a Saturday night, not saying there meets cause trouble because they are all sensible guys but sensible or not in Knox doesn't matter with that cop lurking around waiting for imports, I know firsthand cos I work at the supermarket inside Knox and yep last year I got pulled over bcos he saw me park my car n did a general check which made me late to work (he found nothing wrong n let me go, but still was late to work)
I'm going to ask if the Clubcj.net boys can rock up to this too? We'll have about a dozen CJ Lancers from ESs -> Evo Xs coming if you'd let us partake? Have PM-ed you Adam. Please let me know details and I'll put in the numbers.
Also have contacted the RColt.com boys and we could make a night of this and as one of you pointed out. Fill the entire movie lot out with imports.
Edited by ofey
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
