  • Replies 62
do you actually think before you post threads?
Hamish - Yeah I do. It was posted as a conversation point to get people posting and interacting. Do you think before you reply???
- Chantalle
You need to be able to clean your windscreen - if you go for a roadworthy check or to clear defect, they will check this:
As I mentioned above I don't think it's a bull shit rule, I think it's bull shit that something that can be fixed immediatly be used to defect a car based on the sole discretion of the issuing officer. You'd be pissed if you had to take time off work/whatever keeps you busy, then have to shell out $88 to have a whole new RWC certificate writen, stand in the massive line at VicRoads, all because the water bottle wasn't full.
They should introduce a points system with each dfectable item have a points value rather than just needing 3 things.
Matching front tyres-
When I asked the guy at the tyre service to explain (as I had never heard of this) He explained that it wasn't due to the effectivness and consistency of breaking, like one would assume It's actually due to safety in the event of a blow out and steering capacity.
Having hit my washers once due to a bunch of crap on the window..and having a empty bottle.
All I did was smear the windscreen and lost all visablity, I had to pull over and clean it then filled up at first chance.
I can see why it would be a RWC issue.
that said every cop I have met would not dick some-one for that UNLESS they were being a cock and deserved it..
The fact that you don't have to carry a spare tyre.
But if you do it has to be in roadworthy condition...
This one seems ridiculous at first, but I can see the reasoning for it. Being stuck on the side of the road with a blown out tyre and inability to drive isn't dangerous, but driving with one shagged out tyre is - they'd rather you do the former.
Whilst there are a lot of seemingly bullshit items to get called up on, keep in mind that they were decided at one point for a reason. What I do agree with, is that some should not require an inspection or roadworthy certificate to pass on if you can fix it in the time the officer is there with you. A demerit points system for the vehicle's registration would be better than having to take a day out of work to mess around with clearing a defect. Also, that 90% of the cars on the road would have some roadworthy issue to get called up on if you scrutinised them hard enough...say, in the way that imports get scrutinised. Most people wouldn't believe or have even heard of these roadworthy issues, but reading this thread won't surprise most import owners.
That handbrake click rule is BULLSHIT, technically its legal if it HOLDS the car in place. All it means if your handbrake clicks too much it just needs the cable to be tightened.
Mind you i had my car for 3 years and use the handbrake on "skidpans ;)) and its still tight as f**k, only manage like 5-6 clicks?
Whats with the hand brake rule? I mean as long as it works right? I mean so what if it has one extra click, run for the hills my car is unsafe.
Some of the roadworthy rules are bs, like not being aloud to have metal on your steering wheel. Well my gts2 had a factory fitted momo with a metal centre, try explaining that to a cop or for a rwc.
Same with windscreens, you could replace your windscreen due to minor chips and then drive down the road and cop a stone and your unroadworthy again.
Thing is most cars out there are ''unroadworthy'', I'm sure if they pulled over granny in her ford laser they would find blocked washer jets, rooted 10 year old tyres and no washer fluid.
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
