I've actually found them to be pretty good. the GTR upgrade ones can be a bit mild but they are a good turbo. I would be happy to use some if they were the right price. not much evidence around though so people generally go the more proven options.
tomei b7660 turbo kit - Rb26dett, $4k delivered
tomei m8260 or m7665 turbo kit - RB26dett, $3k delivered
HKS gt-ss turbo kit - RB26dett, $3300 delivered
garrett 2860 -7's or -9's - RB26dett, $2200 delivered.
value for money and proven performance Id simply purchase the garrett's
(almost did a fortnight ago, but decided to stick with my highflows at this stage)
tomei Neo kit - $10k delivered http://cgi.ebay.com.au/Tomei-NEO-KIT-Nissan-RB26DETT-BNR34-Full-Turbo-Kit-/330540455193?pt=Motors_Car_Truck_Parts_Accessories&hash=item4cf5bf1519
NEO-KIT Kit Contents:
ARMS B7660 Turbo Charger
EXPREME Exhaust Manifold
Turbine Outlet Pipe
Head Gasket φ87-1.5mm
Poncam TYPE-B (260-9.15)
Fuel Pressure Regulator
Fuel Rail
Fuel Pump
Nismo Oversized Airflow Meter
Denso 700cc Injectors
Hey all I got a 32 gtr wAt turbos would get around 485hp at all 4s ?? Power outputs ect please help me out cheers
Probably Garrett -5's: enough power with room to move.
Check out the RB26 dyno results thread, hundreds of results to sift through.
  • 9 months later...
Looking for some up to date info and impressions of these kits, especially the 8260 twin kit. Anybody installed and used these kits yet? A friend has just ordered a set for his mostly stock GTR and i'm a bit worried how they are going to go with lag etc.
tomei Neo kit - $10k delivered http://cgi.ebay.com....=item4cf5bf1519
Turbine Outlet Pipe
Fuel Rail
Fuel Pump
Waste of money.
manifolds you dont need for starters and from the results of the ARMS's kits you wouldn't touch them with a 10 foot pole.
  • 5 months later...
any updates on these tomei turbos,anyone else having good or bad results
tomei vs garrett
ive had gt2860-5 found them to be real good,went to gt2860-10 thinking making more power found them to be very bad,in compressor surge and lag
now im interested in finding out what these tomei m7655 and m8260,what size are these compared to garretts,response,power etc
thanks
tomei vs garrett
thanks
Ye people have that issue with -10s...
The ARMS are rubbish as well (as we kinda suspected).
Full thread on them is here:
http://www.skylinesaustralia.com/forums/topic/368988-tomei-arms-m7655-on-rb26/
Turbine Outlet Pipe
Fuel Rail
Fuel Pump
That seems hella expensive. Could you not put that together with Garrett stuff for about $8k? Possibly less?
Turbo $3k
Injectors $1k
AFM/Dump/FPR/Pump/Rail $1.5k
Manifold/Head gasket $1.5k
Cams $1k
I had the m7655 on my stock 260rs, the were on there a week! Absoloute rubbish, tell ur mate to not waste his money! They didn't make boost until 5000rpm and were very linear in the way they made power! They do look good though! Getsomd garretts, they will cost less and perform way better!
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
