  • Replies 482
yer sounds good daniel. :yes: mitch i hear your'e selling your car. leave yer number mate so i can get them onto you. :thumbsup:
Hey mate,
Here's a link to my stagea ad on Antilag....
http://antilag.com/forums/showthread.php?p=874368#post874368
Should have all the info you need.
All the best. :)
It's the fiance's birthday this weekend, so can't make it.
Pretty sure they are, but can anyone confirm that S1 Stageas have same coilpacks as S2 R33. Want to make sure before I order some Splitfires. JustJap list some for S2 w/ NEO, but can only find for 'Nissan Skyline ECR33 (RB25DET) 1/95-5/98'
EDIT: D/w, have had it confirmed in the Stagea section
Edited by Dingus
  • 5 weeks later...
so how can i get hold of a z32 nistune bord for the s1 stagea?
I can get NIStune boards but you need to source the correct Z32 ECU. There is a lot of discussion in the Hypergear thread regarding NIStuning RB25s1's and it seems the general consensus is it's probably better to use an RB20 ECU and an rpm window switch (MSD or an eboost ebc which has a window switch).
G'day Western Stagea owners,
I don't have a Stagea yet but I'm looking at getting one in the next few weeks.
Would love to come and say hello at the cruise on 25 Sept.
Pretty sure I wont have the Stagea by then, so I hope it's OK if I rock up in my HR31 GTS-X :P
Kinda in the same family anyway...
cheers
cheers
It's all good, if my oil pump gears get here in time I will probably attend in my 32gtst :banana:
cheers
Good move Godda, met you a few times in the 31 club (smellyhippy) :)
Stagea is defs a good move
awesome goddo we will take some decent pics with me new camera, SA plates?? lulz
soz bubba gonna go ahead with this meet, theres a few new owners that are interested in that date and we can watch bathurst on the big screen there.
hopefully steve can supply your S2 box by 2015..
SA plates yeah :P for the moment anyway.
What sort of camera?? Here's a quick snap I took tonight. Stock as.
Thanks guys.
Drove it all round the place today so I'm starting to get the hang of it now. So quiet and smooth with the stock exhaust, can barely hear the RB growl or the turbo. Might need to fix that...
Yeah the wheels have grown on me and the offset isn't half bad.
Anyone recommend a good shop for an alarm install? Or a particular system?
cheers
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
