  • Replies 482
Good work tib, Better late than never! (Jim, he used my mate to install it)
Speaking of which, I've still got two board that haven't been collected :ermm: (Darq and bitsMissin I think they are)
P.S. emanage ultimate is crap. If you can't find a tuner in Perth that will tune them, then steer clear.
I'll be giving you a call on sunday so we can have a muck around with the ECU :thumbsup:
Thanks guys.
Was interesting how each of the 4 Stageas that came were a different model or series. RSV, RS4V, RS4S, C34 S1 etc. Pity there wasn't a 260RS to complete the picture.
IMGP9791 by goddohr31, on Flickr
Yellow looked much nicer in person than what I had expected, very nice
IMGP9801 by goddohr31, on Flickr
Heaps more here: JDMWA Cruise 23/10/2011
Edited by Goddo
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
