will your rig be ready soon daniel?
expecting big things from this 60K + build.
hahaha 60K man i wish it had been that cheap basic rundown is car= $35000 (5 years ago), engine= $55000, paint= $15000, stereo= $25000
and to finish it how i want i still have $8000 of gearbox, $7000 of interior and if i can ever find a 32gts4 rear diff to make it awd again.
but it should be all back together stereo and all before christmas but wont be out for any cruises til feb as i am overseas for all of january but the old man will be taking it to motorvatio and will be on dyno there.
  • Replies 482
Meet Time 11ish am
as i am heading too Track on saturday ,
will not be going Sunday ,
Sunday is just a BBQ meet so most can just Chat & leave when you like ,
cheers Chuckie,
i will put BBQ spot up next few days
yo guys i have a misfiring prob with the stag.
i have changed my plugs , coilpacks now r34 gtr with low ks on them and cleaned my afm.
the old plugs where just copper bcpr6e-11 the new 1s that auto pro gave me are bcpr6es.
i have regaped my new plugs form .8 to .7
the misfire is only at idle and u can feel it more when in gear. was told by mel at evoR to take the throttle body off and clean it.
is there any thing else u guys can think of that might cause this?
i know a bit about cars but i not know what else it could be
Nice pics Dave - good to meet some new faces and (and some familiar faces), was a good day :) (Sorry - prob some double up photos.... )
Edited by 32godzilla
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
