  • Replies 127
Bugger... not going to be back by then.
If it's a regular thing- I'm well keen after May.
Justin.
Judging by the amount of interest we got I think we might have to make this a monthly thing!
@TJ, What's there to do on your car to get it going the way you'd like?
Just bought my first skyline on the weekend. Got it home and it misfiring at bout 4500 rpm. Changed spark plugs tonight to find plugs were surrounded by water obviously from where last owner wasn't using coil pack cover. Gave it a squirt to see if new plugs made any change and it seems to of improved to a more croaky note than a misfire. Got home and engine was that hot it smelt like something was burning, and a something near the ignitor sounded like it was sparking.
So I basically want this running cleanly with no misfires or overheating before heading to the track.
coilpacks?
I havn't seen a general thread get so big so fast in the Tassie section for a while.... nice one.
Maybe we should alternate a track day with a working bee day every month??? Or even on the track days, everyone who needs a hand brings they're trucks down for some advice and help???
Just a thought?
Cheers
Justin
yeah, id check coil packs and gapping of plugs, also if its getting really hot, check for air locks in coolant system, mine did similar with heat when i dropped a 2nd motor in :-)
Just had compression test and it came back clear in all cyclinders. Have my coil packs taped up.
Have 2 vacuum hoses that should be replaced aswell as a vacuum hose to brake booster that has been done with heater hose(after engine runs, it sucks hose shut!)
Gave it a crack on way home and blew a hose so will get a clamp put on that hose in morning and try again!
Just a thought?
Cheers
Justin
sounds good :)
I'd be up for a working bee bi-monthly definitely, wouldn't really have any technical skills to bring to the table atm but am happy to be an extra pair of lifting/holding hands and try to learn :P
If these track days were a regular thing I reckon a fair motoring community would build up around them at an entry level, which would be awesome :)
This sounds like a great idea so you can count me in. If I can get my 31 sorted out before then I'll come out for a lash if not I'll just come out to look but making it a regular thing I'd definately be interested especially once the GTR's running.
Yeah I'm pretty sure it's going ahead.
Toffy's got the track all booked.
Not sure how much it's going to cost, is it like $120 each or $120 for the track for all of us? I'm a little confused about that.
Last time I was out there for a private track day I paid to sign up to the Hobart Sporting Club and then to go on the track (so did everyone else) so it was everyone paid individually cant remember the price but it was around the $120 -$140 mark. And it was per car too I think cause one of my friends paid to take his bike out then wanted to take his SS ute out after and he wasn't allowed.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
