Hey Guys, just thought I would let yous know I am selling my loved 1999 RS4 Stagea on ebay due to my growing family :mellow:
It is deffinately a regretful sale
heres the link if anyone is interested
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=150589769522&ssPageName=STRK:MESELX:IT
cheers johnnnyItem number:150589769522 Item number:150589769522
https://www.sau.com.au/forums/topic/360599-my-stagea-on-ebay/
Yeah we already have 3 kids and my wife is pregnant with our 4th!!!!!!
ouch!
That's a position I never want to be in...
3 is enough for me. Plus I would have to HAVE to drive a 7 seater. We already have one and everytime we take it out its like riding on a bicycle....speed wise lol
ouch!
You should get yourself an Elgrand!!!
Power Road Car Sales in Dandy, where I got my R33 4dr, seem to have E51's occasionally, properly complianced as 8 seaters, not as a camper van..
truth. elgrands are the most pimp people mover :thumbsup:
lol... untruth
Your Nissan fanboy status is both obvious and blinding.
Toyota's Vellfire is far and away, greater than the Elgrande as you can clearly see
Back OT, nice S2, best of luck with the sale
lol... untruth
to be fair ive never seen one of those and theyre awesome (i still like elgrands better)
i gotta ask wat r those rims they look sweet. and if it had of been for sale a couple months back i probly would of bought it, but alas it wasnt and now i have one.
