Make: Nissan
Model: Skyline HCR32
Year: 1993
Color: Black
Engine/Driveline:
Kakimoto Regu 06&R Catback
HPI front pipe
Jjr dump pipe
High flow cat
Drift Panel Filter
Splitfire coilpacks
ASI 52mm alloy radiator
GReddy Profec B spec II (13psi)
FMIC kit
Front lip
Welded r200 diff
Interior/gauges
Nismo gear shift knob
Deep dish steering wheel
Suspension & Brakes:
ISC N1 Coilovers
Cusco castor rods
Kazama tie rod ends
Jjr front upper camber arms
R33 Front Lca's
Power spirit rear camber arms
Hicas lock bar + all hicas line removed
alloy subframe bushes
Dba cross drilled and slotted front disc's
Dba vented rear disc's
Bendix ultimate pads F&R
Chassis & Clutch:
Excedy HD clutch
Nismo reinforced clutch pedal bracket
GTR front strut brace
Cusco rear strut brace
Wheels & Tyres:
Gramlights 57D 17x9 +22
F Kumho Ku36 235/45R17
Gt radial 235/45R17
picked this up a few months back with some good plans for it and here is a quick run down on the progress so far.
Took it for a good run out to dubbo with the missus to see the zoo as soon as i got it....took some photos on panorama at bathurst..
DUBBO013.jpg[/b]
after returning from dubbo i instlled a Greddy Profec B spec II and a FMIC
running 13psi through it at the moment, does need to be properly set up but im awaiting a few more parts until then..
added some more better quality pics of the exhaust and wheels
with my chunky sidewalled Kumho put the wheel through the gaurd so needed a new one...got that sorted quick
next up was a diff weld..my standard diff was terrible and would single leg alot...so i fixed it
next i fitted my aero bunnings lip...
Bar off
up close
finished product
thats how it stands ATM..
i have currently a list of things waiting to go on...
*nismo Power brace
*oil pressure, temp and water temp guages.
*looking at my turbo options
* 550cc injectors
*power FC
ill keep the updates flowing
https://www.sau.com.au/forums/topic/360639-kyles-r32-gtst-build/
hey mate
nice clean ride and i like the gramlights for somthing different. they suit it.
im a big fan of the garden edging. on one of the bars i used it on i added some brackets to kick the rear out to blen in with the wheels a little.
example
yeha everyone loves the bunnings lip.....so cheap for the results it is great....
i like the bracket idea DJrift....as they do pull in quite a bit......i guess it shows the wheel width of a bit....
plans for the car is to be of a all rounder.....i really really enjoy drifting so that will be the main focus.......70% drift, 29% circuit 1% drag..
ill only go to the drags with a few friends for some fun....i would love to slide it every oppurtunity i get......
little update
ok lowered it a little more in the front.....about 2 cms...not much....but it was just a trial so i know how much adjustment on the coilover gives me how much more low in regards to body moving downward....
here are some quick pics...
big updates coming....
It's running well. Needs injectors and PFC installed and tuned. Is gangsta now. On actuator boost it runs better then the standard turbo on 14psi.
Is fun.
The modified water line is a bit dodgy ATM. Had to cut the original water line and clamp the new flexible line to it. Needs a flare.
Is fun.
Have a look at Nistune...Ap-Engineering RB20 PFC's are pretty rare these days
thanks man....
painted some things in teh bay today, to generally clean it up.... was going to do the fuel pump but im a bit lazy....will do that a weekend im off work.....
painted slu...i mean strut brace...(GTR item, horrible red, so fixed that) also my cooler core and piping got a little lick of paint....
here are a few pictures
Edited by XkyleX
  • 2 months later...
Alright haven't updated in a little bit.
Sold a few bits and pieces off. Including PFC, AFM and injectors. Needed the money for a overseas trip me and my girl are going on.
On another note. Car is booked for unigroup this coming Friday. For a timing and boost tune.
If your interested in buying my gram lights get at me as I'm currency considering selling them and getting some r33 GTR wheels.
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
