Hi,
We did get the lense and we are looking further into this project to make sure it is viable.
We have also been in contact with a forum member who is willing to donate a pair of fog lights so that we can continue on.
Should have some more progress shortly.
Shane
That would be me guys, I've just bought a replacement front bar that has the the lights in it as well so as soon as I pick it up I have told psi I will be happy to donate them for the greater good ;)
Dale lives not too far away from me so I can drop them over to him no probs. I've just been working away a lot at the moment but I will be home for a while in two weeks so I can pick up said bar.
The ball is a rolling!!!!!
oh Dale you should of mentioned you needed them I have spare fog light housings I could sent you with the lense... doh...
Sorry mate, I didn't realise you had the whole lot. We just want to check how the mounts are set out so that we can come up with a solution that means as little work for you as possible. As I read that some of you are heating up the glue to get the lenses off and it may warp the surround. Any solution we come up with will need to be mass produced and include instructions for anyone to follow. I don't want hiccups or people saying this isn't a DIY job further down the track, so bare with us.
I did some searching a while back when I read Phil's original thread about attempting this and came across these pics on JDM Styling (I think), forgot i had them on my phone.
Just goes to show it can and has been done on a S2. After the glass cutting is done does anyone know what kind of bulbs can be used? as in if a big orange bulb is put behind the clear will it just look orange again or will it be far enough back to not stand out?
Sorry to disappoint you guys
but the second pic was photoshopped :D
and i still currently have the orange
OK if someone can pause time fo me I can actually continue the project... my time gets eaten by work.
105-110mm diamond hole saw, a wood jig to hold the lense, a drill and a heap of water, I already have the spare glass lenses waiting
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
