i hammered in the rear restrictor about 20mm then filled it to the top of the block with that liquid metal stuff you mix together with your fingers.
1.5 restrictor at the front and i brazed up the vct feed and drilled it to 1.5mm
n1 pump. I had problems on the dyno with oil blowing out the rocker breathers and i figured i had a bit of blowby and the oil could not drain back so i just pulled out the dipstick and have had no problems!
  • 1 month later...
Please don't use the standard restrictors.
I've had 3 sets of restrictors in mine. - R32 RB25DE Head.
  1. Standard (over 5500rpm = filled catch can)
  2. blocked rear with a 1.5mm front (not enough oil on start up)
  3. and finally 2 x 1.3mm which is perfect.
RB25det - blocked rear and a 1.5mm is apparently ok. Others may be able to share their cold start storys with the same setup.
The blocked rear and 1.5mm up front was fine once warm but cold starts I could hear something knocking about up top rear on the exhaust side - coincidentally that's the furthest away from the front 1.5mm restrictor.
With the 2 x 1.3mm all noises disappeared and all sounds sweet again. Also - no catch can filling either.
  • 4 weeks later...
hey guys i have a question, i have rb30et bottom end with s1 r33 rb25 head, thinking of running the stock rb30et oil pump
and most of the time i will be using it on the track. what oil restrictors would i need to use/get if any at all?
sorry for the n00bness :worship:
+1 for using two 1.3mm restrictors.
Just using one 1.5mm might be ok for a solid lifter setup.
my setup with 2x 1.5mm was still pumping way too much oil to the head as soon as you took it past 6000. its just been changed to 1x 1.5mm and 1x 1mm with a couple extra oil drains directly to the sump for good measure.
will see how it goes this time round.
1x 1.5mm is not enough for the hydraulic lifters (for solids sure that will work), 2x 1mm can be hit and miss, works for some gives lots of lifter noise for others.
when i brought my oil restrictors i just brought 2 blanks, one of which im drilling out to 1.5mm. iv already put the blank in ontop of the rear oil restrictor and its nice tight fit
I'm getting a adjustable feed for my 25/30 oil control problem, it is externally adjustable and will be set so when at high rpm the oil will be high enough for cooling and lubrication but will not overflow, by rights this should still see enough oil at low rpm to feed my lifters.
With my 2 head drains and the drain from the can to the sump hopefully the oil is going to stay in the motor.
Hopefully.
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
