The id1000's are almost half the price of id1600's and id2000's, 1600's and 2000's are 250each ouch...and I thought jap injectors were hefty
In my old setup I had bosch 1600's (indy blues) and they were only 90bucks each
ID 1600's 2000's. Do it. You will never have to think/worry about it again. Sell the 700's and the changeover will not be that bad. :thumbsup:
I found ID1000's for a bit over $ 100 US each, reasonable ?
im interested in where u got those prices as well - there are some fakes floating as well so need to be careful when purchasing
Just be careful on where you get them. I was told mine were ID2000s but are really Bosch 2200cc. They are pretty much the same injector just not modified like the genuine IDs are
so are the id's modified bosch items? what is the difference?
Mine arent genuine ID's either, they are the local Xspurt modified ones but at $650 who cares. They are 1000cc Bosch EV14 injectors with a guaranteed spray consistency, local warranty and they idle perfectly. I will be giving them a workout soon.
http://www.xspurtinjectors.com/
Basic Specifications Nominal Flow Rate - 2225cc/min @ 3.00 Bar (43.5 psi) Using Gasoline at 52 Degrees C (125 Degrees F)
Thats straight off the ID website!
And for anyone that has issues with these injectors not being able to idle or what not.... here you go!
The guy I bought them off says they are identical but Injector Dynamics just adds on the fancy anodised tip and charges extra for them.
Let me report back with my results after the tune as most of us are still sitting on the fence. My mate who owns autostyle had a gtr 'dardvl' which made 450awkw back in the day and I think that also had 700's
They are ID ones by the looks of the extender, Keep in mind they are only Bosch injectors flow matched and tested, I asked the guys at AZNEW today when I ordered my proflow fittings, they said theirs come in Bosch boxes and are unmodified.
I had a bad experience with the bosch 2000's one injector flowed 7-8% more at idle and fouled the plug real bad.. Im guessing injector dynamics found the same problem and is probably why they push the flow matched sets that you pay a premium for..
From my experience you will need to run bigger injectors then 700's to make 400kw+. When I was making 374 RWKW I ran 700cc Sards with a duty cycle of up to about 96. At the advice of my tuner (a reputable one)I upgraded to Sard 800's to allow for more headroom. This allowed me to run a bit more boost and make 390 RWKW. Now the dc gets to about 85. This is with a -5 2.7 setup. I wonder why the difference between my experience and some others in this thread? Is it just a difference in dyno readings? I know of others with similar results to mine.
Tim.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
