From my experience you will need to run bigger injectors then 700's to make 400kw+. When I was making 374 RWKW I ran 700cc Sards with a duty cycle of up to about 96. At the advice of my tuner (a reputable one)I upgraded to Sard 800's to allow for more headroom. This allowed me to run a bit more boost and make 390 RWKW. Now the dc gets to about 85. This is with a -5 2.7 setup. I wonder why the difference between my experience and some others in this thread? Is it just a difference in dyno readings? I know of others with similar results to mine.
Tim.
i know that extra capacity chews up DC due to the additional torque & your setup is a 2.7ltr as well
my old 3ltr had 1600's & dc was above 60% & that was making 405awkw
Tim.
Wow now that is a very different results indeed mate.
I don't think an extra 50cc is going to make a 30% duty difference from a 2.65 to a 2.7
3ltr would of course but very interesting indeed.
As i said earlier best i can get under full load in 4th is 64%
Suck it an see Marko!!
ash, the displacement of a gtr engine is 2568cc hence a deficit of just under 150cc.
I'm leaving the 700's in there and see what happens when dyno tuned
Rebuild with larger pistons etc? :)
Really need to know where the power is made. If he makes 400kw at 9000 rpm his going need more injector than a car that makes 400kw at 7000 and falls away to 380 by 8000...
Is that pull done in 3rd gear? What is your rev limit set to? Afrs look good no unnessarry fuel used there.. I'm on sard 800's aswell made 450awkw rev limit 8600 power just starting to nose over at 8.4 on 98/toluene mix. My Afrs are a bit rich at 11.0 though. Engine efficiency would play role aswell..
Dyno pull done in 4th. Rev limit set at 8300. Very rarely need to rev over 6500 though to drive it quickly.
I dont have another picture of the graph just now but you can just see that the afr settles dead on 12.
Tim.
  • 3 years later...
I cannot find exactly what I was looking for in this thread, could have missed it?
What size injectors are needed for an RB30/26, Nitto 3.2Lt stroker to use 98 & E85 , building for response ?
Have to find out what is in it before I get worried about it, it had a lot of mods before I bought it and ready for some high HP if the previous owner wanted to turn up the wick.
I am sure the builder will not have their results suffer because of the wrong injectors after doing this type of build, would not look good :/
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
