19 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey Guys,
Seeing as the last track day was a raging success I was thinking we should do it again.
I've added a poll to ask what track you think we should go to. I'm still in favour of Baskerville because it's closer to home and there is less things to run in to.
June 12th seems like a good day for it too. Both tracks are free from what I can see.
Cheers,
https://www.sau.com.au/forums/topic/362050-sau-tas-track-day-2/
  • Replies 171
Posted Images
Hey Guys,
Cheers,
this is a disolution the same as the drift guys. Symmons actualy has better run offs and the sand traps actualy stop cars. its been a while since a car has made as big a mess of itself as the Shaw s13 recently. Not having a go but just taking the bad omen off the track.
i want to do symmons one day this year...BUT..atm my car is not up for the high speed nature of it yet.. need to fix the gremlins before risking the long trip.
ive driven both tracks now and the speed is very similar. the back straight of barsky for me was 190 ish which is very similar to symmons depending on wind.
the long trip is another aspect. you guys could hire a room at cosy cabbins. cheap as chips.
ive only recently driven Barsky in lap mode and i can say its a far more exciting track for the driver. there is more to be gained/ learnt as an amature/ enthusist.
im very keen to bring my car back and try again.
its just a pitty that the track has a rubbish surface and that its subject to changing weather conditions every 5 mins.
+1 for barsky
Well that's a load off, I'm already peeing my pants about drifting there.
just had a look at cams calendar and june 11th is drift prac day at symmons. not sure if this will afect any of you guys but thought id mention it.
i will definatly be out if it is june 12th. that said dont arange it around me.
I might consider a go at baskerville if I get car running nice for this one. Seems baskerville got plenty of run off room for me to learn to use this thing called boost lol.
Need to get new coilpacks and possibly exhaust gasket and evaluate performance first though.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
