Recently bought an r33 with these pre-installed and want to remove them...anyone got advice on how to do so and how easy it is? I have no removal instructions at all and haven't found any after searching. Looks like they're connected to the ECU, but never having touched electronics I don't want to fiddle too much without getting some advice first.
Cheers
wtf is a LEBC and a DFA ?
if its just crap thats tapped into the wiring then disconnect the battery and start chopping, tape up anything thats not insulated - dont want shit shorting out
as long as nothing is actually broken and run through these jaycar components you should be alright, if wiring has been broken and is running through these units then u gotta bridge it back together, if this is too complicated dont do it yourself lol, it'll just make the next guys job even harder
IEBC = elec boost controller
DFA = Digital Fuel Adjuster
They come as electronic kits from Jaycar which you put together
Might be better selling the ECU with these installed and then put the $$$$ towards getting a nistune/pfc/vipec etc etc
Someone starting out will buy it as a first step performance upgrade???
Uncover the ecu. If you are lucky they will be connected with a loom extension so just unplug that and put the original plug back into the ecu.
If not: the wires are connected to the wires going into the plug and you can either unsolder them or just cut the wires off and tape up the exposed joins WITH TWO EXCEPTIONS
1. The IEBC interrupts the signal to the boost solenoid so you will have to remove the Jaycar wires from the wire going to the boost solennoid pin and join back together the cut ends of the boost solenoid wire. You will also have to replumb the vacuum/boost lines under the bonnet going to the solenoid and to the wastegate actuator.
2. The DFA interrupts the signal from the afm so again the wire going to that pin has been similarly cut and will need to be rejoined.
What car is it on and why are you taking it off?
If you are not sure about this don't start or you may end up with a dead engine.
Ask if you want more info.
Thanks for the reply. They're on a Series 2 R33.
Want to remove them and try the car stock, seems a little sluggish compared to my previous S1. Also have a turbotech manual boost controller which did a decent enough job, so would rather get the jaycar stuff out and hock it and put the manual BC in.
The iebc is a great unit, I would rate it over the manual one. The dfa is just jaycars equivalent of a safc. Have you shout about getting it tuned? With should eliminate the sluggishness. Food for thought
I had a Jaycar ebc. It was a great unit - took a little practice to find how it worked but could adjust speed of build boost finely. Also had a switch so you could have two complete maps. ( I only sold it because I got a Link which will do the boost control as well). Ran it with a SITC SLD and SAFC as I had an auto Stagea at the time - their unique ecus don't allow for nistune or other aftermarket ecu but now manual so all good.
If you dont have any idea on electronics, then playing around with AFM wires probably isnt advisable becuase you dont want to get that signal wrong.
I've accidentally wired a Z32 AFM backwards and it survived.
Uneek: See me on the w/e and I'll take a look.
you were damn lucky nothing else... electronics are a very touchie thing, the wrong voltage could kill something important in the afm or worse the ecu
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
