  • Replies 91
where do u live as someone might be able to come take a look on the way home?
Kambah, unfortunately I finish at 8pm and won't be home till 10pm cos Canberra buses ARE FCKED!!! (from Fyshwick)
i live in kambah if you need a mechanic to look at it?
That would be awesome! Let me know when you have some free time?
I suppose I could have a look at it for you sometime.
Shouldn't be that bad, I have tiny hands like the Japanese intended and have owned a supercharged aw11 mr2 for about 3 years.
Lol
Thanks Jimmy :)
shell, when one of those strapping young lads go over to fix it make sure that you clean the face where the starter bolts to the gearbox.
Mir had an issue with the s14 starting and it just turned out to be a bad earth (through the body of the starter) Found this out after pulling the suspected alarm apart >_<
Oh, and make sure you makes em sammiches.
The alarm doesn't quite explain a grinding noise like you described earlier.
Is the battery good?
Is everything earthed sufficiently?
Is the starter getting enough power?
If so then the starter motor becomes a pretty decent suspect given what you've described so far
James I actually did think about the alarm too, as another possibility.. maybe the immobiliser not letting fuel through or something..
But I think the starter motor is more likely.
Does the motor crank over shell...I think i read somewhere that it sounds like it has no fuel.
But is the motor turning over?
Well the battery isn't *that* old and I've had batteries die before in my old R33 and this is different.
I really don't know with the earthing and stuff :(
See my post on the previous page.... but yeah it was, but not anymore (stopped on the weekend)
RS4 can probably provide more clues when he has a look at it, and if it still isn't figured out then I'm in nearby Theodore and can see if I can figure it out.
Electrical issues suck!!
Thanks heaps :)
yeh it's frustrating when you just want to get it fixed but you don't have the knowledge! It's my only mode of transport and it's killing me :(
Oh yeah, I know the feeling. I have an old MR2 as well.
That's the feeling Toyota talk about in their tv ads, the feeling of being stuck on the side of the road with no means of transport.
Lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
